Solve 5 Moles Ideal Gas Thermodynamic Work - Final Temp
The problem involves five moles of an ideal monatomic gas undergoing expansion, with given initial temperature, heat absorbed, and work done. Participants are exploring the implications of the first law of thermodynamics in this context.
  • Participants discuss the application of the first law of thermodynamics, questioning the validity of using certain equations under non-constant volume conditions. There are inquiries about the meaning of dQ and how to approach the integration of heat flow without a given function.
Some participants have provided guidance on using the first law of thermodynamics and the relationship between internal energy and temperature. However, there remains uncertainty about the correct application of these concepts, and multiple interpretations of the problem are being explored.
There is confusion regarding the assumptions made about the process being non-constant volume and the lack of a specific function for heat flow. Participants are grappling with how to properly apply the first law given the provided values.
Luongo
1. Five moles of an ideal monatomic gas with an initial temperature of 124*C expand and, in the process, absorb an amount of heat equal to 1140J and do an amount of work equal to 2200J . What's the final temperature
2. Q=m1.5R delta T
3. I tried adding 1440 to 2200 as Q and solving for T final but that doesn't work help?
2. Q=m1.5R delta T
This is a first law problem. Q=m1.5R delta T only works at constant volume. But you know that this is not a constant volume process - [how?].
Write out the first law. You are given the heat flow, dQ and the work, PdV, so what is the change in internal energy? Then you can determine the temperature from the change in internal energy.
AM
First of all what is dQ, do you want me to integrate something I am not given a function? or is there another differential so that i can take the derivative of a function if so what function? you said I am given the heat flow does that mean i take the integral of 1140 and get 1140Q? then what am i supposed to do with that? because dQ = Q'(t)dt. I'm not given a function... i don't understand. please tell me what formula i use?
The formula you use is the first law of thermodynamics. Write out the first law as it applies to the thermodynamic system ie. the gas. You are given dQ. dQ is the heat flow into/out of the gas. You are given dW. dW is the work done by the gas. Plug those into the first law an that gives you dU. It is that simple.
Once you have found the change in internal energy, you can find the change in temperature. What is the relationship between change in internal energy and temperature?
AM
  • · Replies 33 ·
  • · Replies 21 ·
