Potential Energy & Tippipng Forces
The discussion revolves around calculating the potential energy required to tip an object traveling at a constant velocity and determining the force necessary to achieve this tipping. It involves concepts from physics such as kinetic energy, potential energy, and the geometry of the object in question.
  • One participant presents a calculation for kinetic energy and potential energy, questioning the correctness of their approach to determine tipping conditions.
  • Another participant suggests that the initial calculations are reasonable but points out a missing factor of gravitational acceleration in the energy balance equation.
  • The second participant provides a revised formula for the tipping condition based on the object's geometry and the angle of the ground surface.
  • Further clarification is given regarding how to calculate the tipping force based on the angle of the surface and the object's mass.
  • A later reply confirms understanding of the calculations and expresses appreciation for the assistance provided.
  • There is a mention that the angle for tipping depends on the specific geometry of the object, indicating variability in calculations for different objects.
Participants generally agree on the approach to calculate the potential energy and tipping force, but there are nuances in the calculations and assumptions regarding angles and object geometry that remain open for further exploration.
The discussion includes assumptions about the object's geometry and the conditions under which the tipping occurs, which may vary with different objects and scenarios. Specific values for angles and heights are derived from the geometry presented in the initial post.
This discussion may be useful for individuals interested in mechanics, particularly in understanding the dynamics of tipping objects and the calculations involved in potential and kinetic energy. It may also benefit those studying physics or engineering concepts related to forces and motion.
glocki35
Hi All,
I have a problem i am trying to figure out, if an object (scale drawing in attachment) is traveling at a constant velocity of 2.16 m/s, with a mass of 496 Kgs, what is the potential energy required to 'tip' this object over?
Kinetic energy = 1/2 Mass x Velocity^2=1/2x496x2.16^2 which = 1157.07 Joules, all good, however;
Potential Energy= Mass x (sqrts^2+a^2-s)=496x(sqrt6.09^2+0.79^2)-6.09 = 496 x (6.14-6.09) which =25.3 Joules
which means, at this velocity this object will tip if it strikes an object on the ground.
Does this seem correct?
Also, how can i calculate the force required to tip this object over?
I have put scale drawing in as an attachment to help.
I am confused and at a complete standstill.
Any help is greatly appareciated.
glocki35: Nice work (almost). Your approach seems like a reasonable approximation, for when the base of your object, traveling along the ground, strikes a hard stop (an obstruction) on the ground, provided we neglect strain energy temporarily stored at the contact site (which I did not want to include, because we would need the mass distribution of the striking body, and the stiffnesses of the two colliding entities at the contact site, not to mention it would be too detailed). You, however, made one minor mistake; you forgot to multiply by gravitational acceleration, g. Therefore, your current energy balance equation should instead be 0.5*m1*v1^2 = m1*g*h, where v1 = impact velocity, h = max[0, (6.09^2 + 0.79^2)^0.5 - (6.09/cos(theta))] m, and theta = downward slope angle of ground surface. Solving the above energy balance equation for v1 gives, v1 = (2*g*h)^0.5. According to this analysis, if the velocity of your object equals or exceeds v1, your object will tip over when it strikes the obstruction.
Therefore, if the ground surface is horizontal, theta = 0 deg, h = 0.051 026 m, and v1 = [2(9.81 m/s^2)(0.051 026 m)]^0.5 = 1.001 m/s. If theta = 5 deg, then h = 0.027 763 m, and v1 = 0.738 m/s. If theta = 7.4 deg, then h = 0 m, and v1 = 0 m/s. In other words, if the ground surface slopes downward 7.4 deg, your object tips over even when its velocity is zero.
The tipping force required to tip the object over would be F = m1*g*tan(7.39 deg - theta), where m1 = object mass, and theta was defined earlier. Note that if F is negative, no additional force, other than gravity, is required to tip the object over.
Hi NVN,
that is a great response, I understand where you are coming from, i was going to ask before your second post how i could calculate the force required to tip at an angle, however you have already answered this for me.
Thankyou kindly, I really appreciate this!
I can now move onto the next problem it seems.
Cheers
Glocki35
glocki35: To answer your PM question, the 7.39 deg angle in post 2 comes from the given object geometry, shown in your diagram. The angle will be different for different objects. The angle depends on the object geometry. For different objects, determine this angle in a manner similar to the method you used in your post 1 diagram.
  • · Replies 62 ·
  • · Replies 54 ·
