Inferring charge via electric field properties
The discussion focuses on inferring the net charge of a charge distribution based on electric field measurements at two distances: 1.5m with a field strength of 282 N/C and 2m with a field strength of 119 N/C. The relationship between electric field strength and distance is explored, indicating that the field does not decrease as 1/r². Instead, participants suggest using the ratio of electric field strengths and distances to derive a more accurate model for the electric field's behavior. The equation E = kq/r² is referenced, along with the derivative E' = -2kq/r³ to analyze the change in the electric field.
  • Understanding of electric field concepts and measurements
  • Familiarity with the equation E = kq/r²
  • Basic calculus, specifically differentiation
  • Ability to interpret graphical data and curves
  • Study the mathematical derivation of electric field strength from point charges
  • Learn about electric field lines and their graphical representation
  • Explore the implications of the inverse square law in electrostatics
  • Investigate the relationship between electric field strength and charge distribution
Students studying electromagnetism, physics educators, and anyone interested in understanding electric field behavior and charge inference techniques.
phil ess
You are 1.5m from a charge distribution whose size is much less than 1m. You measure an electric field strength of 282 N/C. You move to a distance of 2m, and the field strength becomes 119 N/C. What is the net charge of the distribution? HINT: Don't try to calculate the charge. Determine instead how the field decreases with distance, and from that infer the charge.
E = kq/r2
Well the electric field strength doesn't fall off as 1/r2, because if we calculate q for 1.5m using simple substitution, then use that q at 2m, I don't get the electric field given.
How do I figure out the field? If I am thinking graphically, I have two points (1.5,282) (2,119) and I have to find a curve that crosses those two points, a curve that describes how the electric field falls off.
I think the problem I am having here is that I am rusty on the math. I have a feeling that it would help to differentiate E = kq/r2 to perhaps be able to describe how the field is changing:
E' = -2kq/r3 But I am not sure how to use the given points to help...
E2/E1 = 0.422
r2/r1 = 4/3
Any hints would be appreciated!
  • · Replies 32 ·
