Energy lost from Wind Turbines
The discussion focuses on the impact of wind turbines on wind energy dynamics and local pressure changes. It establishes that while wind energy is converted to mechanical energy by turbines, this process does not lead to energy loss but rather energy extraction. The conversation highlights that the largest wind turbines primarily influence the first 200 meters of the atmosphere, and the energy extracted is minimal compared to the overall wind energy available over larger distances. Additionally, it notes that the conversion of wind energy to electricity results in a cooling effect on the atmosphere, as the heat that would have dissipated is utilized instead.
  • Understanding of wind energy dynamics
  • Knowledge of thermodynamics related to energy conversion
  • Familiarity with aerodynamic principles
  • Basic concepts of mechanical energy and electricity generation
  • Research the aerodynamic effects of wind turbines on local wind patterns
  • Explore the thermodynamic principles of energy conversion in wind turbines
  • Investigate the environmental impact of large-scale wind energy extraction
  • Learn about the design and spacing of wind turbines for optimal energy capture
Engineers, environmental scientists, and renewable energy professionals interested in the effects of wind turbines on energy dynamics and atmospheric conditions.
Hunterbender
What is the effect of wind turbines on the aerodynamic of the wind system? Since energy is conserved, will excessive turbines lead to a leakage of wind energy and transformed into mechanical energy? [or concert to heat?]
Also, what is the effect of the local pressure? Thanks in advance.
Science news on Phys.org
All wind energy is caused by and eventually gets dissipated as heat. Friction with the ground, trees, and viscous friction in the air dissipate the wind energy. If you use a wind turbine to capture this energy, the heat energy that would have been dissipated is instead converted to electricity, making the atmosphere cooler. But fear not: virtually all electrical energy is also eventually dissipated as heat.
Don't forget that the largest wind turbines only affect about the first 200 m above the ground, so there is a lot of atmosphere above the turbines. One has also to look at the separation between the turbines.
Dynamic pressure is affected immediately behind the turbines and the wind would be slightly less, but then the extracted energy is a small factor compared the wind energy over several km - before, above and after the turbines.
Rather than lost, I think a better term would be extracted by the turbine or removed from the wind.
  • · Replies 22 ·
  • · Replies 43 ·
25K
  • · Replies 30 ·
