| Thread Closed |
Complex solutions to a differential equation a vector space? |
Share Thread | Thread Tools |
| Oct6-09, 12:50 AM | #1 |
Is the set of all complex solutions to the differential equation [tex] \frac{d^2 y}{d x^2} + 2\frac{d y}{d x} - 3 y = 0[/tex] If so, find a basis, the dimension, and give the zero vector 2. Relevant equations 3. The attempt at a solution I solved the equation and got the answer: [tex]y(x) = C_1 e^{-3x} + C_2e^x[/tex] I know how to test if a set is a vector space but I'm not really seeing the "set" here. Is it because [tex]C_1[/tex] and [tex]C_2[/tex] can be complex numbers? In which case, wouldn't any complex number work so would I get the set of all complex numbers? any help is appreciated |
| Oct6-09, 01:56 AM | #2 |
Recognitions:
i think you missed out somthing in your question -
I'm assuming it is, "is the set of all complex solutions to the differential equation - a vector space" I would start with the axioms for a vector space - what are they? Then what is the general form of your solution? This will generally have some undetermined constants to give a family of solutions "the space" is then the set of all solutions. Is it a vector space? In short, a vector space is closed under scalar multiplication and addition, with some other axioms, so check: closure under scalar multiplication - so given any solution is a scalar times the solution also a solution closure under addition - so given 2 solutions is their sum also a solution then fill out the other axioms |
| Oct6-09, 02:05 AM | #3 |
Recognitions:
updated post above
| Oct6-09, 05:52 AM | #4 |
Complex solutions to a differential equation a vector space?[tex]\{ f(x)= C_1 e^{-3x}+ C_2 e^x : C_1, C_2 \in \math{C}\}[/tex]. If you add two such functions is the sum also a function of that kind? If you multiply such a function by a complex number is the product also a function of that kind? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Complex solutions to a differential equation a vector space?
| Basis - Complex Vector Space and Real Vector Space | Calculus & Beyond Homework | 5 | ||
| Vector of differential solutions | Calculus & Beyond Homework | 10 | ||
| Basis of the vector space of solutions to a differential equation. | Calculus & Beyond Homework | 1 | ||
| existance of unique solutions for differential equation | Calculus & Beyond Homework | 0 | ||
| Verify solutions of differential equation | Calculus & Beyond Homework | 6 | ||
