Can Anyone Help Identify These Stepper Motors?
  • Thread starter Thread starter bassplayer142
    parts
The discussion revolves around identifying and utilizing stepper motors salvaged from a printer, focusing on their specifications, potential applications, and methods for testing and controlling them. The context includes both theoretical understanding and practical experimentation related to stepper motors.
  • Experimental/applied
  • One participant seeks help identifying stepper motors from a printer, providing specific model numbers but lacking datasheets.
  • Another suggests mapping the windings using a multimeter or continuity tester as a method to identify motor connections.
  • A participant proposes applying a 5-volt supply to test the motor's response and mentions the importance of marking the motor for visibility during testing.
  • There is a discussion about the motor's specifications, including a voltage rating of DC24.2V and a step angle of 3.75 degrees, with a participant questioning if this voltage is the maximum allowable.
  • One participant notes that the step angle of 3.75 degrees is relatively coarse compared to more common 1.8-degree motors, which could affect performance.
  • Concerns are raised about the power requirements of the motor, suggesting that a significant current may be needed, which complicates the design of a suitable driver circuit.
  • A participant mentions the possibility of salvaging driver chips from the original printer but later indicates they have already discarded them, expressing a willingness to experiment with lower voltages and alternative methods.
Participants express varying opinions on the suitability of the stepper motors for the intended application, with some suggesting they may not be the best choice due to their specifications. The discussion remains unresolved regarding the optimal approach for using these motors in a laser scanner project.
Participants have not reached a consensus on the best method for controlling the motors or the implications of their specifications on performance. There are also unresolved questions about the maximum voltage and current requirements for safe operation.
This discussion may be of interest to hobbyists and engineers experimenting with stepper motors, particularly those looking to repurpose motors from other devices or seeking guidance on motor control and application in projects like laser scanners.
bassplayer142
I have multiple stepper motors i pulled out a printer and I can't seem to find any datasheets on anything. For example one of the motors is made by OKI and it has numbers 3Y25AE1 and QH4-4490. I have looked all over the internet and I can't find anything. If anyone knows a good idea to try it is greatly appreciated. Thanks
If needed, you can easily map the windings using a multimeter or a simple DC continuity tester.
If you have a 5 volt supply able to supply an amp or two, you can watch the shaft of the motor while you put the 5 volts across the different wires. If nothing happens, reverse the polarity.
It is worth marking the motor or attaching a sticky label to the shaft as the movement can be very quick and you might miss it.
Something else you can do is to do a search for the printer you took the motors out of and try to get a circuit diagram. This will tell you quite a lot about the stepper motors.
Most of these motors have two separate windings and 4 wires. this means they are bipolar motors and need their polarity reversed during rotation.
We had a similar question a few months ago and I found the following website then which seems to cover stepper motor theory quite well.
http://www.haydonkerk.com/ResourcesandDownloads/StepperMotorTheory/tabid/192/Default.aspx
Thanks for the input. I don't know much about stepper motors at all as I have never used them, but I am willing to learn. I should have included that on the sticker it also says DC24.2V 3.8(ohm) and 3.75Deg/Step.
Is that voltage the maximum voltage that can be applied to the motor? I'm not looking for torque at all since a mirror will be mounted on the motor so 5V-12V with the same speed output would be sufficient. I'm trying to build a laser scanner with it. thanks again.
To make this work, you have to identify the windings, then build a driver to control in sequence which coils to activate:
Unless you especially like that stepper motor, it may not be the best choice.
3.75 degrees per step is pretty rough as most stepper motors seem to be 1.8 degrees per step.
3.75 means 96 steps per rotation while 1.8 means 200 steps per rotation.
Also, that power requirement is pretty inconvenient. 24.2 volts across 3.8 ohms is 6.3 amps.
It might work on less, but if you have to be switching and reversing 24 volts at 6 amps, that will be a serious controller.
You would need to drive a controller chip like a L297 with a microprocessor and this L297 would drive a power amplifier like a ULN2075 which would then drive the stepper motor.
On the printer you pulled apart, there may already be similar ICs to these, and they could be worth salvaging as these chips are not cheap.
Ouch, I already threw away the chips. I'm really just experimenting right now so if the degree/step is too high I can always buy a better one or develop another way like galvos. I think I will just experiment with lower voltages and a mcu and see what I can do. Thanks for the input.
