Find Absolute Maxima and Minima of f(x) on [-2,2]
The discussion revolves around finding the absolute maxima and minima of the function f(x) = (2x)/(x^2 + 1) on the interval [-2, 2]. The subject area is calculus, specifically focusing on critical points and the behavior of derivatives.
  • Participants discuss the derivative of the function and its implications for identifying maximum and minimum points. Questions are raised about the behavior of the derivative at these critical points.
Some participants have provided insights into the relationship between the derivative and the critical points, noting the need for the derivative to equal zero for sign changes. There is an acknowledgment of the complexity of the problem, with some expressing difficulty in solving it.
One participant suggests reviewing additional resources to better understand the assignment and the concepts involved in finding extrema.
the_ace
1. Find the absolute maxima and the absolute minima of the following function
f(x)=(2x)/(x^2+1) on [-2,2]
i found the derivative = (2x^2-2)/(x^2+1)^2
Okay, what will the derivative be at a maximum point?
I can't solve it
A maximum would occur if the derivative exists and changes sign from positive to negative at a certain point.
A minimum would occur if the derivative exists and changes sign from negative to positive at a certain point.
This means the derivative must pass through zero to change the sign. So, equate your derivative to zero and solve for the x coordinates of these points. In Calculus, these points are called critical points.
Just in case you don't understand, I'd recommend the following resources:
http://ltcconline.net/greenl/courses/115/applications/frsttst.htm
http://www.math.wvu.edu/~hjlai/Teaching/Tip-Pdf/Tip1-21.pdf
http://www.math.ucdavis.edu/~xiaoh/16a/extrema.pdf
It's important to understand what the assignment is on before attempting it.
12K
