Is the derivative of (ln x)^2 a u-sub?
  • Thread starter Thread starter amb1989
    Derivative
The discussion revolves around the differentiation and integration of the function (ln x)^2, specifically whether a u-substitution is appropriate and how to correctly apply integration by parts.
  • Participants explore the use of u-substitution and integration by parts, questioning the correctness of the derivative and the application of the integration formula.
Some participants have offered guidance on the application of integration by parts and the need to revisit the derivative of (ln x)^2. Multiple interpretations of the problem are being explored, with no explicit consensus reached.
There is uncertainty regarding the correct application of the integration by parts formula and the derivative of (ln x)^2, with participants suggesting different approaches to clarify these points.
amb1989
Is this a u-sub? I went through and got 1/(2x)^2 but I am not sure if that is correct.
You can use a substitution, but the answer is not quite 1/(2x)^2.
How did you arrive at that answer?
Actually I asked the wrong question.
I'm working on an integration by parts problem it asks me to integrate what is in the topic title.
I went about it by saying that U = ln(x)^2 and that dv = 1.
When I went through and plugged everything into the integration by parts formula I arrived at
xln(x)-(integral sign)(1)(1/(2x)^2)
The thing that I am getting hooked up is trying to take that integral of 1/(2x)^2. I think I messed up somewhere but I am not sure where to look. Any suggestions?
Hmm I am not really sure how you ended up xln(x)-(integral sign)(1)(1/(2x)^2).
I would choose the same parts as you did, i.e. u = (ln x)^2 and dv = 1, but I am not sure you applied the formula correctly.
[tex]\int u dv =uv - \int v du[/tex]
Is that what you are using?
Yeah that's what I am using. du = 1/(2x^2) v= x
(lnx)^2)(x)-(integral)(1/(2x)^2)(1)
Did I take the derivative of (ln(x))^2 wrong?
Yea maybe have another look at the derivative of (ln x)2
You could use the substitution z = ln(x), or treat it as (ln x)2 = (ln x)(ln x) and apply the product rule.
