Induced EMF on a primary coil by a secondary coil
The discussion focuses on deriving an equation for the induced electromotive force (EMF) on an inner solenoid caused by a changing current in an outer solenoid. The existing equation for the induced EMF on the outer solenoid is given as EoRMS=(No*Ai*(2*pi*f)*(permeability constant)*IiRMS)/Li. Participants suggest starting with Faraday's law, specifically V_{induced} = -N(dφ/dt) = -NA(dB/dt), to establish the relationship between the changing current and the induced EMF. Additionally, applying Ampere's law is recommended to connect the rate of change of current in the outer coil with dB/dt.
  • Understanding of Faraday's law of electromagnetic induction
  • Familiarity with Ampere's law
  • Knowledge of solenoid properties and configurations
  • Basic concepts of electromotive force (EMF) and magnetic fields
  • Study the derivation of Faraday's law and its applications in electromagnetic systems
  • Explore the relationship between current changes and magnetic field variations using Ampere's law
  • Investigate the properties of solenoids and their mutual inductance
  • Learn about the implications of induced EMF in practical applications, such as transformers
Students and professionals in electrical engineering, particularly those focusing on electromagnetic theory, solenoid applications, and circuit analysis.
KaiserBrandon
1. Derive an equation to find the induced EMF on an inner solenoid by a changing current on an outer solenoid.
We're given the equation EoRMS=(No*Ai*(2*pi*f)*(permeability constant)*IiRMS)/Li for the induced EMF on the outer solenoid by a changing current in the inner. I need an equation to replace this for when it's the other way around.
I have no idea where to even begin, I just need a hint as to how I should start.
Start with Faraday's law for a coil:
[tex]V_{induced} = -N\frac{d\phi}{dt} = -NA\frac{dB}{dt}[/tex]
where N is the number of coils in the inner coil, B is the magnetic field and A is the area enclosed by the coils.
Can you apply Ampere's law to determine the relationship between the rate of change of current in the outer coil and dB/dt?
AM
  • · Replies 41 ·
9K
