DFT: What is the physical meaning of the symmetry about the nyquist frequency?
The discussion centers on the physical meaning of the symmetry observed around the Nyquist frequency when performing a Fast Fourier Transform (FFT) on a dataset. It is established that the imaginary component of the reflected half has the opposite sign to the first half, while the real component remains unchanged. This phenomenon is an artifact of representing a real signal in the frequency domain, where the coefficients of negative frequencies are complex conjugates of their positive counterparts. The periodicity of the Fourier Transform leads to this reflection, and MATLAB's FFTSHIFT function is commonly used to rearrange the frequency components for better visualization.
  • Understanding of Fast Fourier Transform (FFT) and its applications
  • Knowledge of complex numbers and their conjugates
  • Familiarity with Nyquist frequency and sampling theory
  • Experience with MATLAB, particularly the FFTSHIFT function
  • Explore the mathematical foundations of the Discrete Fourier Transform (DFT)
  • Learn about aliasing and its implications in signal processing
  • Investigate the use of MATLAB's FFTSHIFT for frequency domain analysis
  • Study the relationship between time-domain signals and their frequency-domain representations
This discussion is beneficial for signal processing engineers, data analysts, and researchers working with Fourier analysis and digital signal processing techniques.
jsparger
When I take the fft of a set of data and plot it, there is a reflection around the nyquist. Everybody knows this, but I would like to know what the physical meaning of the second half (the reflected half) is.
The real component is the same as the first half, and the imaginary component has the opposite sign.
I can use the first half of the data to reconstruct my signal, and I understand how it relates to frequency and phase angle, but I am not clear on the second half. Can I reconstruct my signal from this half of the data as well? Why do the frequencies have the opposite phase angle? These frequencies correspond with frequencies that could be aliasing if you extend the frequencies with the same spacing (for example, I am not clear whether you should take the info to be arranged as:
0 up to near the Nyquist, back down to near zero (so that the second half is some other expression of the first half of the data, i.e. it corresponds to the same frequencies;
or
0 up to near the Nyquist, rest is junk; (second half means nothing)
or
0 up to near the Nyquist (first half), then up to near the samplingFrequency (second half), as in the second set corresponds to higher frequencies that may be aliasing.
where k is the frequency spacing = samplingFrequency/numberOfSamples
Maybe this is just an artifact of the DFT. If not, could somebody explain to me what it means? Feel free to ignore the blather above, since I really have no clue what I am talking about. Just would like to know what the reflection corresponds to physically, and why the imaginary part is opposite.
Thanks
--John
Mathematics news on Phys.org
It's an "artifact" of starting with a real signal. In order for a complex FT to represent a real signal, the coefficient of -f must be the complex conjugate of the coefficient of +f. And there's a periodicity in a FT, repeating the spectrum every ##f_{Max}##, i.e. every ##n## points.
Putting these things together, for an ##n## point digital FT, the value at ##(n/2)+m## is the same as the value at ##(n/2) + m - n = -(n/2) + m = -[(n/2) - m]## from the periodicity, and this is the complex conjugate of the value at ##(n/2) - m##. Thus the values at ##m## above the midpoint and ##m## below the midpoint are conjugates.
It's common practice to swap the upper and lower halves for plotting, so that the corresponding frequency values go from -(n/2) to (n/2) instead of 0 to n. MATLAB has a built-in function FFTSHIFT that does this.
