| Thread Closed |
I don't know how to find the normal force on this problem |
Share Thread | Thread Tools |
| Oct9-09, 05:32 PM | #1 |
1. A m = 3.0 kg wood box slides down a vertical wood wall while you push on it at a θ = 49° angle. What magnitude of force should you apply to cause the box to slide down at a constant speed?
2. Fk-Mk*n 3. i know there are 4 forces acting on the object. gravity, normal force from the wall, kinetic friction, and the force that i applied. but i do not know how to set up the equation to solve this problem |
| Oct9-09, 05:43 PM | #2 |
Do you know how to draw a free body diagram?
| Oct9-09, 05:47 PM | #3 |
yea i did one but the n is on the x axis so that means i need to know the F to get the normal force right?
| Oct9-09, 05:53 PM | #4 |
First off, you have to neglect friction since you do not know the kinetic friction coefficient of the surface. Second, the normal force doesn't cause the block to move in what you defined to be the x direction. Are you using newton's second law for net force in the x and y directions?
| Oct9-09, 05:54 PM | #5 |
| Oct9-09, 05:55 PM | #6 |
Hi xstetsonx! Welcome to PF!
![]() For constant speed, you need zero acceleration, which means zero net force in both the x and y direction. So call the force F, find N, and then find ľN.
| Oct9-09, 05:58 PM | #7 |
so the total force will be
mK*Fcos49-mg+Fsin49? |
| Oct9-09, 06:02 PM | #8 |
| Oct9-09, 06:02 PM | #9 |
You should get
[tex]F_{app} - F_{k} - mg\sin(\theta) = 0[/tex] [tex]n - mg\cos(\theta) = 0[/tex] The algebra's up to you. Edit: |
| Thread Closed |
| Thread Tools | |
Similar Threads for: I don't know how to find the normal force on this problem
| Find the normal force and magnitude of acceleration. | Introductory Physics Homework | 4 | ||
| Find the Normal Force | Introductory Physics Homework | 1 | ||
| Normal Force, Friction Force, Accel problem | Introductory Physics Homework | 2 | ||
| trying to find a normal force | Introductory Physics Homework | 6 | ||
| can't find normal and tension force...please help | Introductory Physics Homework | 2 | ||
