Calculating Distance and Innerproduct in 4-D Minkowski Vector Space
The discussion focuses on calculating the distance and inner product in a 4-D Minkowski vector space, specifically for the events represented by the vectors (4ns, -1m, 2, 7) and (2ns, 3m, 1m, 9m). The distance formula is defined as d=(Δx²+Δy²+Δz²)¹/², while the space-time separation is calculated using Δs=(c²Δt²-Δx²-Δy²-Δz²)¹/², where c is the speed of light. The inner product is confirmed to be the dot product of the two vectors, but clarification on whether the vectors are contravariant or covariant is necessary. The discussion emphasizes the importance of consulting course materials for definitions and terminology.
  • Understanding of 4-D Minkowski vector space
  • Familiarity with the distance formula in physics
  • Knowledge of inner products and dot products
  • Basic concepts of space-time intervals and event representation
  • Study the properties of 4-D Minkowski vector spaces
  • Learn about the speed of light and its role in space-time calculations
  • Research the differences between contravariant and covariant vectors
  • Review the definitions of distance and space-time separation in relativity
Students studying physics, particularly those focusing on relativity, as well as anyone interested in understanding the mathematical foundations of space-time and vector calculations in higher dimensions.
Maepez
In the 4-D Minkowski vector space [you can think of this as the locations of events in space-time given by (t, x, y, z)] consider the vectors pointing to the following events: (4ns, -1m, 2, 7) and (2ns, 3m, 1m, 9m)
(a) Find the distance between the events.
(b) Find the innerproduct between the two events.
Distance Formula
My initial thoughts are to "subtract" one point from another to get a vector from the first point to the second. Then take the square root of the sum of each component squared. The only thing that bothers me is the different units (ns and m).
For part (b), the inner product is just a dot product of the two original vectors. Is that a correct assumption? (I've never studied anything like this before, and it seems important.)
Thanks in advance for any advice!
I'm pretty sure that by "distance between the two events", they mean [itex]d=(\Delta x^2+\Delta y^2+\Delta z^2)^{1/2}[/itex]...If they asked for the space-time separation (or interval) between the events, then you would calculate [itex]\Delta s=(c^2\Delta t^2-\Delta x^2-\Delta y^2-\Delta z^2)^{1/2}[/itex] (Using the convention that [itex]s^2=c^2t^2-x^2-y^2-z^2[/itex] )...However, different authors will use different terminology, so you should check with your Professor. Alternatively, the definition of "distance between events", that you are expected to use might be found in your text, or at least your notes.
As for the inner product, are the 4-vectors you posted contravariant or covariant? What is the definition for the inner product between two 4-vectors that is given in your text/notes?
Thanks very much for your reply, gabba. It seems my intuition was leading me in the right direction on the distance. Unfortunately, the only information I have was posted in the question. I'll consult the text, too, with the ideas you have given me. As far as note are concerned, I don't have anything covering Mindowski vector space. We're discussing Eigenvectors in class and something completely different in the homework. :\
  • · Replies 18 ·
  • · Replies 82 ·
9K
  • · Replies 0 ·
