What is the Inductance of a Coil with Changing Magnetic Field and Current?
  • Thread starter Thread starter JDiorio
    Inductance
The problem involves calculating the inductance of a coil with a specified number of turns and dimensions, placed in a changing magnetic field. The current through the inductor starts at zero and increases over a set time period, with specific rates of change provided.
  • Participants discuss the use of various equations related to electromotive force (emf) and inductance, questioning how to incorporate given parameters like the number of turns and diameter. Some express uncertainty about deriving emf from the provided information.
Multiple approaches to the problem are being explored, including the potential use of calculus and the possibility of solving without it. Some participants suggest that certain information may be extraneous, while others are seeking clarification on the relevance of all given data.
There is a noted constraint regarding the class's non-calculus focus, which affects how participants approach the problem. The lack of explicit information about the coil's length is also a point of discussion.
JDiorio
An inductor has the form of a coil with 2074 turns and a diameter of 1.9 mm . The inductor is placed in a magnetic field perpendicular to the plane of the coil and increasing at a rate of 0.48 T/s . The current in the inductor is zero at t = 0, and then increases to 6.9 mA at t = 1.0 s. What is the inductance?
This is the problem, I am obviously missing something.
I want to use the equation L= (u*N^2*A)/length.. but as you can see I am not given the length. I do not know how to incorporate the charge into finding the inductance.
I feel like I am close. I am trying to use the increase rate of the magnetic field to find the emf, and then use the emf and the current to find the inductance, but then i get stuck.
So I found the formula emf= -L ( dI/dt) where d = change in. How do I derive the emf from the information given. Also, this formula does not involve the number of turns nor does it involve the diameter.. so is this just extra information?
You can the equation as
emf = - NAdB/dt = L*di/dt. Or
NA(dB/dt)*dt = L*di
Take integration on both side and find L.
is there anyway to do this problem without calculus? This is a non-calc based class so i have no clue how i would go about taking the integral..
In the given problem, dt is given(1s). di is given(6.9 mA). Substitute in the formula to get the inductance. No need to take integration.
thanks a lot.. i finally got this stupid question.. really appreciate the help! thanks again..
  • · Replies 0 ·
