Thread Closed
Work-Energy Theorem: Effect of increasing speed vs stopping distance.
Share Thread Thread Tools
Oct11-09, 04:14 PM   #1
If the speed of a car is increased by 50%, by what factor will the minimum braking distance be increased assuming all else is the same? Ignore the driver's reaction time.
2. Relevant equations
[tex] W = Fd \cdot cos\theta [/tex]
[tex] W = \Delta{E_k} [/tex]
3. The attempt at a solution
First i declared:
[tex] Fd = \frac{1}{2}mv^2 [/tex]
Where d would be the stopping distance, there is no final velocity because its stopping. I then stated:
[tex] Fd = \frac{1}{2}m(1.5v)^2 [/tex]
[tex]Fd = \frac{1}{2}m\cdot2.25v^2
[/tex]
so due that F, the applied braking force is constant, the mass remains constant of course, the only thing that changes is the kinetic energy is multiplied by 2.25, so for Fd to correspond, d would have to be 2.25 times larger correct?
This question has no answer in the key..
Personal Reference: Q24 p. 145
Im always so horrible with these questions that don't give any data for the variables .. :S
Thanks,
Senjai
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct11-09, 09:23 PM   #2
bump again :( can someone please.. pretty please, confirm :)
Oct12-09, 01:46 AM   #3
You're first declaration: F*d = (1/2)*m*v^2 seems logical, you're assuming all kinetic energy must be reduced to zero by the work done through braking.
The assumption that the braking force is constant in both situations seems adequate for the problem.
If speed is increased to 1.5 that of the original, you look good in saying that d should be 2.25 times as long as originally determined. Your work makes sense to me.
Thread Closed
Thread Tools
Similar Threads for: Work-Energy Theorem: Effect of increasing speed vs stopping distance.
Thread Forum Replies
Find Speed of car based on stopping distance and decceleration. Introductory Physics Homework 1
Potential energy increasing in j-t effect Classical Physics 0
Model Airplane-Work-Energy Theorem and Kinetic Energy Introductory Physics Homework 2
kinetic energy: car stopping, finding speed of car Introductory Physics Homework 2
Free energy? increasing speed of a fluid in a nozzle General Physics 5
