Calculating driving force from wheel rpm, wheel radius and engine power
The discussion revolves around calculating the driving force of a car's engine using inputs such as power, wheel radius, and wheel RPM. Participants explore the relationship between power, torque, and force, while considering the effects of gear ratios and vehicle dynamics. The context includes theoretical derivation and practical application of these calculations.
  • Paul Harris presents an equation for driving force based on power, wheel radius, and RPM, questioning the validity of his results which yield a low maximum acceleration.
  • Some participants suggest starting the derivation from the engine's power and torque, indicating that the current approach may lead to incorrect values.
  • Another participant emphasizes the importance of velocity in the power equation, noting that acceleration varies with speed.
  • Paul Harris clarifies the need to eliminate torque from the equation due to a lack of direct torque information, proposing that his method of deriving force from power is valid.
  • Participants discuss the implications of the calculated driving force and whether the resulting acceleration seems reasonable for a production car.
Participants express differing views on the validity of the equation and the approach to deriving driving force. There is no consensus on whether the calculations and assumptions made by Paul Harris are correct or if they lead to reasonable results.
Participants highlight the dependency on various assumptions, such as neglecting friction and drag, and the need for accurate values for torque and gear ratios. The discussion also reflects on the limitations of using power alone to calculate driving force without considering other factors.
This discussion may be of interest to automotive engineers, physics students, and enthusiasts exploring vehicle dynamics and the relationships between power, torque, and acceleration.
paul_harris77
I have spent a while trying to work out a simple equation to give me the driving force of the engine in a car using the inputs: Power, wheel radius and rpm but when I put in real numbers from a production car, I get low values of 2197N. The equation I have derived is:
Driving force = 30*P/(rpm*r*pi) where P is the power of the engine in Watts, rpm is the rpm of the wheel after it is geared down, and r is the radius of the wheel.
Assuming there are no passengers or even a driver and the effects of friction and drag etc. are neglected, by my calculation of the maximum acceleration in first gear, given a car mass of 1420kg, is 1.5ms-2 which seems to me to be too low even for a slow car.
To derive the equation I just used, the equations P=Tw, Torque= Force*wheel radius and w = (rpm*pi)/30, where w is the angular velocity, T torque and P power.
Can anyone verify if this equation is right and whether I have done something wrong?
Many thanks
Regards
Paul Harris
The derivation is... different i'll give you that.
A tip for deriving this sort of stuff, start from where the power and torque are made (ie the engine). Then trace it along to the wheels. It's not working becucase you are putting in wrong values into an equation that won't acutally give you what you want. Where did you get the values you are sticking into that equation?
You don't even need power to calculate the triving force, its all done with torque.
Torque*gear ratios = wheel torque.
Then WT= F* radius.
Convert power to torque at the start if you don't have a torque figure.If you are using power to determine acceleration, and therefore force you need a velocity.
Hi Paul Harris-
First, the relation between force F and acceleration a is:
F = ma
Force times displacement dx is work (joules)
Force times work per unit time dx/dt is power (watts)
But dx/dt = velocity v
So P = Fv = mav (Newton-meters per second) = watts
You are already aware that it is easier to accelerate from zero to 10 mph than from 70 mph to 80 mph. The velocity v in this equation is why.
Now, write power as torque T (Newtons) times angular velocity w (radians per second) where RPM is wheel RPM.
P = 2 pi T RPM/60
P = 2 pi T RPM/60 = mav.
That's it. The wheel RPM is directly proportional to velocity, so once you know torque, mass and velocity, you can calculate acceleration. Note all units except RPM are metric.
Bob S
Thanks for your replies guys.
I suppose I should have stated that I need to eliminate torque from the equation. This is because the force needs to be calculated from a Power vs. engine rpm curve. I have no direct information on the engine torque so it needs to be calculated from the power (P=Tw).
Converting engine rpm to wheel rpm is simple enough (multiplying by the gear ratio). Acceleration does not really need to be calculated, it was just to check if my equation for force was producing sensible answers.
I canceled the 2/60 part of the equation to give 1/30 and eliminated T by using T=Fr. Is this right and does then then mean that my equation is in fact technically correct and producing correct answers? Doesn't 1.5ms-2 for a car's maximum acceleration seem a bit slow to anyone? The data I used was a max power of 124kW at 5900rpm (engine rpm) and a 1st gear ratio of 2.92:1 producing a wheel rpm of 2021rpm and according to my equation, 2197N of driving force. The wheel radius is 0.2667m.
Thanks again
Paul H
  • · Replies 18 ·
  • · Replies 107 ·
41K
  • · Replies 19 ·
  • · Replies 23 ·
  • · Replies 23 ·
12K
  • · Replies 22 ·
