FestiveF
Basic lower level physics questions...
Hi all! I am new to the forum and I have a few lower level physics problem with which I am confused. Any help and explanations will be immensely appreciated!
1) A steel pipeline is 1500 m long and is at a temperature of 30 degrees celsius. How much shorter will it be if the temperature falls to 10 degrees celsius?
*I got .36 m...
2) How much heat is absorbed by 255 g of methanol when it is heated from 10 degrees celsius to 60 degrees celsius?
*I got 3.12 x 10^4 J...
3) Calculate the number of kJ of heat energy liberated by 4 kg of steam at 100 degrees when it is condensed, cooled, and changed to ice at 0 degrees.
* I got 1.2 x 10^4 kJ...
4) If the density of mercury is 13.59 x 10^3 kg/m^3 at 20 degrees celsius, what will its density be at 65 degrees celsius?
5) In a certain hydraulic lift, the small piston has a radius of 15 cm. The large piston has a radius of 26 cm. A force of 225 N is applied to the small piston. What is the mass of the crate that is being lifted by the application of this 225 N force?
Thank you SO much ahead of time ~
*I got .36 m...
