What is the Radial Probability Density for a Hydrogen Atom in the Ground State?
The discussion revolves around calculating the radial probability density for an electron in the ground state of a hydrogen atom, specifically focusing on the probability of finding the electron within a certain radius.
  • Participants discuss the appropriate use of the radius in the probability density formula and the integration limits for calculating the probability. There is confusion about the correct interpretation of the formula and the role of delta r in the context of a volume integral.
The conversation includes attempts to clarify the integration process and the relationship between the probability density and the volume element in spherical coordinates. Some guidance has been provided regarding the integration limits and the form of the probability function.
There is mention of specific values, such as the Bohr radius, and the need to integrate from a lower limit of r = 0 to an upper limit of 3.75a0. Participants are navigating the implications of these constraints in their calculations.
w3390
Calculate the probability that the electron in the ground state of a hydrogen atom is in the region 0 < r < 3.75a0.
a0=.0529 nm
P(r)=4(Z/a0)^3*r^2*e^(-2Zr/a0)
I am confused because I am not sure if I am supposed to use 3.75a0 as my radius. I guess I am not supposed to since I did that and got it wrong. I cannot figure out what else to do. However, I have also seen the probability density written as:
P(r)[tex]\Delta[/tex]r=[4(Z/a0)^3*r^2*e^(-2Zr/a0)][tex]\Delta[/tex]r
If this is the correct formula, I am not sure what to use for delta r.
Any help would be much appreciated.
You don't use dr. This is a volume integral in radial symmetry. You use dV = 4πr2dr. You carry the integral from lower limit r = 0 to upper limit r = 3.75a0.
Okay I do that and I get a volume of 9.81e-29m^3. How do I get this into a probability function?
You misunderstood what I said. The integral includes the probability density so that
[tex]P=\int \psi^*\psi\; 4\pi r^2 dr[/tex]
Okay. Gotcha. Thanks for the help.
  • · Replies 21 ·
