How is this possible? What is voltage? 7.2 KV going through this small wire?
  • Thread starter Thread starter foo
    Voltage Wire
The discussion revolves around understanding voltage, particularly in the context of a voltage transformer that operates at 7200 volts. Participants explore the nature of voltage, its relationship to current, and the physical characteristics of the transformer and its components, including a wire that seems unexpectedly thin for such high voltage. The conversation includes technical explanations, conceptual clarifications, and some debate regarding the components observed in the transformer.
  • One participant expresses surprise at the thin wire in the transformer, questioning how it can carry high voltage without difficulty unless a high current load is drawn.
  • Another participant suggests that the wire may actually be an insulator and questions the presence of a wire running through it, proposing it could be a fragment from the equipment failure.
  • There is a discussion about the nature of voltage, with one participant describing it as a pressure difference that pushes electrical current through a circuit, noting that high voltage can exist with low current.
  • Some participants speculate about the quality of workmanship and the potential causes of the transformer failure, with suggestions that the wire may be slag from melted power cable or mounting hardware.
  • One participant compares voltage to water pressure in a pipe, explaining that current is akin to the amount of water flowing, while voltage represents the pressure pushing the water.
Participants express varying views on the nature of voltage and the components of the transformer. There is no consensus on the identity of the wire or the cause of the transformer failure, indicating multiple competing views remain.
Some assumptions about the components and their functions are not fully resolved, and there are references to images that may clarify the discussion but are not included in the text.
foo
I finally got to see the inside of a voltage transformer as one happened to blow up and I got to view a part of it. The wild thing was that since it was a 7200 volt transformer I thought that there would be some thick wire in there. Well, the top portion of it has one little itty bitty wire traveling through it and it blew my mind that it could carry such high voltage without difficulty, well, unless somehow a high current load is drawn through it causing it to blow. Heh
Here is the pic of what I'm talking about:
http://foo.gearsector.com/foo/images/PTa_mini.jpg
http://foo.gearsector.com/foo/images/PT_mini.jpg
Ok, so then what is voltage? I have read many times about how it's what pushes current. But what the heck is "THIS", the this that's pushing? I get the idea that current is the atoms moving through something. Current I can imagine. But voltage? I can't imagine what voltage is. How can something push when it's not anything at all?
What gives?
Thanks in advance!
P.S. And why can so much voltage transfer through such a small wire? It's weird how the wire connecting to the top is so thick...
That looks more like an insulator - designed to hold high voltage wires away from the tower.
http://upload.wikimedia.org/wikipedia/en/thumb/3/33/Pylon.detail.arp.750pix.jpg/250px-Pylon.detail.arp.750pix.jpg
Not sure why it would have a wire running through it unless that was a fragment of cable that became embedded when the equipment failed.
Anyway - voltage and current are different.
You can think of voltage as the pressure difference to push electrical current through a circuit. You can have very high voltages with very little current - the spark when you wear polyester clothes can be 100,000V but there is very little current.
It's just the top part of the transformer that blew off. I will take another picture tomorrow of a whole x-former to show. Sorry to confuse.
Also, the top picture is upside down. There is a connector not shown. Like I wrote, I'll post another pic tomorrow.
That was my first take, mgb. It could be an insulator that is mounted on top of the transformer.
Why is the conductor running so far off-center? And did this cause the failure, or is this the usual quality of workmanship for these insulators?
There wouldn't be a conductor running through the middle of this.
My guess is that it's a bit of slag from the power cable / mounting hardware that got melted by the fire.
http://foo.gearsector.com/foo/images/x-former_mini.jpg
The proper term for these insulators are http://en.wikipedia.org/wiki/Bushing_%28electrical%29" .
http://en.wikipedia.org/wiki/File:DIN_52NF1000.jpg
[PLAIN]http://en.wikipedia.org/wiki/File:DIN_52NF1000.jpg[/QUOTE][/URL]
How does the bushing work?
You can compare it to water flowing through a pipe.
The current is the amount of water that flows through per second.
And the voltage corresponds to the pressure i.e. how strongly the pump pushes the water into the pipe.
  • · Replies 23 ·
  • · Replies 35 ·
10K
  • · Replies 21 ·
  • · Replies 20 ·
