Argument for why can't I see through a table
  • Thread starter Thread starter Nickmate
    Argument Table
The discussion revolves around the question of why light cannot pass through solid objects, specifically a table. Participants explore the atomic structure of materials and the behavior of photons in relation to these structures.
  • Participants discuss the atomic composition of materials and the size of atoms and electrons. Questions are raised about the energy of photons and their interaction with matter. There is a comparison made between different materials, such as glass and diamond, regarding atomic spacing and light transmission.
The discussion is ongoing, with various perspectives being shared. Some participants suggest that the size of atomic gaps is not the only factor affecting light transmission, while others explore the implications of atomic vibrations and collisions on photon energy. No consensus has been reached yet.
Participants reference specific atomic measurements and the limitations of human vision in detecting small gaps. There is an emphasis on the complexity of light interaction with solid objects, which remains a point of inquiry.
Nickmate
Objects are composed of atoms. Atoms are nucleii surrounded by electrons. The electrons are tiny in comparison to the gaps between each other, and between electrons and the nucleus. This means that there are significant gaps between atoms in objects.
A typical human eye will respond to wavelengths from about 380 to 750 nm.
The size of an electron is 2.82 × 10-15 m.
The diameter of an atom ranges from about 0.1 to 0.5 nanometers
What is happening to the energy of the photons of light?
Also your first argument would apply equally well to glass.
In fact carbon atoms are closer together in a diamond than they are in coal
Humans can't see the gaps in tables just because they are too small to detect with the human eye. Instruments may be able to detect light from the other side of the table if photons could get through.
Spacing between carbon atoms is 0.1415 nm
Atomic diameter is 10^-9 m, or 1nm for helium, and 10-15nm for its nucleus.
From a model I have seen, the spacing between carbon atoms in diamond is the diameter of one carbon atom. That means that in diamond, there is a similar spacing between the outer electrons in the atom, and the edge of the nucleus, to electrons in the outer orbit of adjacent atoms. It's still easier for photons to pass between atoms than through them though, obviously. I presume that since the atoms are vibrating, and there are so many of them in a solid object, it is impossible for a photon to pass all the way through without colliding with enough atoms to reduce its energy to the point where it gets absorbed.
  • · Replies 152 ·
12K
  • · Replies 69 ·
13K
16K
12K
9K
