Spring Oscillation: Find Greatest Speed of 0.5kg Block
  • Thread starter Thread starter Leviticus 08
    Oscillation Spring
The discussion focuses on calculating the greatest speed of a 0.5 kg block attached to an ideal spring with a spring constant of 100 N/m. When the spring is compressed by 12 cm, the block's speed is measured at 1.5 m/s. The relevant equation for velocity in simple harmonic motion is v = sqrt(k/m) * sqrt(A^2 - x^2), where A represents the amplitude and x is the displacement from the equilibrium position. To find the maximum speed, the amplitude A must be determined using the given parameters.
  • Understanding of simple harmonic motion principles
  • Familiarity with Hooke's Law and spring constants
  • Basic knowledge of kinematics and velocity equations
  • Ability to manipulate algebraic equations for problem-solving
  • Calculate the amplitude A using the given speed and displacement values
  • Explore the derivation of the velocity equation for oscillating systems
  • Investigate the effects of varying spring constants on oscillation speed
  • Learn about energy conservation in simple harmonic motion
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to explain concepts of simple harmonic motion and spring dynamics.
Leviticus 08
A 0.5 kg block attached to an ideal spring (k = 100 N/m) oscillates on a horizontal frictionless surface. When the spring is 12 cm shorter than its equilibrium length, the speed of the block is 1.5 m/s. What is the greatest speed of the block?
The force becomes F(x) = m a - k x
The equilibrium position is x = m a / k
I don't know what else to use
I don't really have all the work at my fingertips I left it at home(I'm at work now)
I'm not looking for a solid solution just somewhere to start
The velocity of the block is given by
v =sqrt(k/m)*sqrt(A^2 - x^2) where x is the displacement from the equilibrium position.
Substitute the values and find the A.
For maximum velocity x = ...?
  • · Replies 18 ·
