Proving the Relation between Angular and Frequency Power Spectral Density
  • Context: Graduate
  • Thread starter Thread starter KFC
    Density Power
The discussion revolves around the relationship between power spectral density in terms of angular frequency and frequency, specifically examining the equation 2πP(ω) = P(ν). Participants explore how to prove this relation without knowing the functional form of P(ω), and whether it holds under various conditions.
  • One participant questions how to prove the relation 2πP(ω) = P(ν) without knowing the functional form of P(ω).
  • Another participant suggests that the relation serves as a scale factor to ensure that the total power remains consistent regardless of the function argument.
  • Counterexamples are presented, notably using P(ω) = 1/ω², leading to P(ν) = 4π²P(ω), which challenges the initial relation.
  • Some participants argue that the relation is valid in the context of integrals but not necessarily for the expressions alone, raising concerns about the counterexamples.
  • A participant critiques the assumption that P(ν) and P(ω) are of the same functional form, proposing to differentiate them by using subscripts (Pν and Pω) to clarify their distinct nature.
  • It is noted that for the power in any frequency interval to be consistent across both functions, they cannot share the same functional form.
  • Participants discuss the derivation of the relation using infinitesimal frequency intervals and integrating over finite intervals, emphasizing the need for consistency in total power calculations.
Participants express disagreement regarding the validity of the relation 2πP(ω) = P(ν), with some supporting it under specific conditions while others provide counterexamples that challenge its universality. The discussion remains unresolved with multiple competing views on the relationship.
There are limitations regarding the assumptions made about the functional forms of P(ω) and P(ν), as well as the implications of using different symbols for the power spectral densities. The discussion highlights the complexity of integrating power spectral densities over different frequency intervals.
KFC
Suppose the power spectral density denoted by [tex]P(\omega)[/tex] where $\omega$ is the angular frequency and [tex]\omega = 2\pi \nu[/tex], I wonder how to prove that
[tex]2\pi P(\omega) = P(\nu)[/tex]
without know the functional form of [tex]P(\omega)[/tex]. I saw this relation in some book, but I don't know how to prove that.
It looks like a scale factor needed to insure that the total power (integral) is the same whatever the function argument (integral differential) is.
Disproof by Counterexample:
Suppose [tex]P(\omega) = 1/\omega^{2}[/tex] then [tex]P(\nu) = 1/\nu^{2} = 4\pi^{2}/\omega^{2}[/tex]
Thus
[tex]P(\nu) = 4\pi^{2} P(\omega)[/tex]
Thus
But I saw the statement about this somewhere else, like mathman said, when you integrate the power spectral density, no matter on [tex]\omega[/tex] or [tex]\nu[/tex] you should get the same energy, so you will find a relation between [tex]P(\omega)[/tex] and [tex]P(\nu)[/tex]. But as to your example, I don't know why it leads to this ...
What I was trying to say was in essence:
[tex]d\omega = 2\pi d\nu[/tex]
Yes, that's what I mean. But what I am thinking to pseudophonist's example is: [tex] 2\pi P(\omega) = P(\nu)[/tex] is only valid in the sense of integral but not the expression alone, right? Otherwise, how do you explain the counter example?
The fallacy in pseudophonist's example is that he assumes that P(ν) and P(ω) are of the same functional form, and that going from one to the other is merely a matter of changing what symbol is used for the argument. However, in order to satisfy the condition that the power in any frequency interval is the same as measured using both functions, it's pretty clear that they can't be of the same functional form (even though we are confusingly using the same symbol, P, for both). So let's not use the same symbol for them. Let's call the power per unit frequency interval Pν(ν) and the power per unit angular frequency interval Pω(ω) (by adding the subscripts, we've used a different symbol for each spectrum, making it clear that these are in fact two different functions).
First of all, the sloppy physicist's derivation of the result is to talk about the power in any "small" (i.e. infinitesimal) frequency interval being the same regardless of what kind of frequency you're talking about. Hence:
Pν(ν) dν = Pω(ω)dω​
and since
2πdν = dω​
The result follows immediately:
Pν(ν) = 2πPω(ω)​
A more mathematically sensible version of the derivation is to talk about the power over some *finite* frequency interval (which is calculated by integrating the power spectral densities over that interval). It shouldn't matter whether you're using angular frequency or just plain old frequency: you should get the same answer for the total power in that interval:
[tex]\int_{\omega_1}^{\omega_2} P_{\omega}(\omega)\, d\omega = \int_{\nu_1}^{\nu_2} P_{\nu}(\nu)\, d\nu[/tex]​
Again, it's pretty clear that, for this condition to be satisfied, there's no way that Pν(ν) and Pω(ω) can be of the same functional form.
Pν(ν) dν = Pω(ω)dω​
and since
2πdν = dω​
Pν(ν) = 2πPω(ω)​
Thanks. Make sense
  • · Replies 21 ·
  • · Replies 16 ·
