How Does Throwing an Anchor Overboard Affect a Barge's Buoyancy?
  • Thread starter Thread starter Brianjw
The discussion revolves around a problem in buoyancy and fluid mechanics, specifically examining the effects of throwing an anchor overboard from a barge on its buoyancy and water displacement. The scenario involves an iron anchor and a barge floating in freshwater.
  • Participants explore how the anchor's position affects the water displacement when it is on the barge versus when it is thrown overboard. Questions arise regarding the initial displacement caused by the anchor on the barge and the subsequent effects on buoyancy.
The discussion is ongoing, with participants providing hints and prompting each other to consider the forces acting on the barge in both scenarios. There is an emphasis on understanding the displacement of water and the implications of the anchor's position.
Participants note that the weight of the barge is unknown, which raises questions about how this impacts the overall analysis of the problem. There is also mention of the anchor being suspended above the riverbed, which may influence the discussion on buoyancy.
Brianjw
This last problem seems to be causing me the most trouble:
Dropping Anchor. An iron anchor with mass 35.0 kg and density 7860 kg/m^3 lies on the deck of a small barge that has vertical sides and floats in a freshwater river. The area of the bottom of the barge is 7.95 m^2. The anchor is thrown overboard but is suspended above the bottom of the river by a rope; the mass and volume of the rope are small enough to ignore.
After the anchor is overboard and the barge has finally stopped bobbing up and down, has the barge risen or sunk down in the water?
By what vertical distance?
I'm not sure how to start this problem since the weight of the parge is unknown, but I'm guessing somehow that doesn't matter. Any suggestions?
Here's a question to help get you started:
When the anchor is on the deck, how much water does it displace?
if the anchor has not rested on the bottom then the answer is neither
another hint
Not true.
Brianjw: First answer gnome's question (that will get you thinking properly). Then consider all the forces acting on the barge in both cases.
  • · Replies 29 ·
9K
