Force and acceleration and graphs
The discussion revolves around the relationship between force and acceleration, particularly in the context of a problem involving a cart and spring scales. Participants explore whether acceleration and force are identical or merely proportional, and how this relates to their graphical representations.
  • Conceptual clarification, Problem interpretation, Assumption checking
  • Participants question the nature of the relationship between force and acceleration, specifically whether they are the same or just proportional. There is also confusion regarding the problem setup involving two spring scales and the forces acting on a cart.
Some participants have provided clarifications about spring scales and have noted that the problem lacks sufficient information for a complete solution. There is ongoing exploration of the concepts involved, with participants expressing uncertainty about how to proceed.
Participants have pointed out that the problem description may be inadequate, particularly regarding the forces and resulting acceleration when both spring scales are applied. There is an indication that additional information may be necessary to fully address the question posed.
Physicshelpneeded
i know that acceleration and force are similar and dependent on one another...but are they always the same and are their graphs always identical? or are they just proportional? :frown:
Also, anyone know how answer this question:
two forces are applied to a cart with two different spring scales (whats a spring scale?) the spring scale F1 reads 2.0 N. the cart moves toward the left with acceleration towards the left of 2.50 m/s/s. what does spring scale F2 read? :confused:
i know i need to use proportions to solve this...or at least i think so...but i don't know where to start...thanx for all ur help in advance guys :smile:
A spring scale is simply a method of reading the spring force.
The problem description is not adequate to solve . Ray
ok...at least now i have an idea of what a spring scale IS...but i still have no idea how to go about solving this problem...anyone have any ideas? :frown:
For a given mass, the net force applied is proportional to the resulting acceleration. For example: Double the force and you double the acceleration.
Not enough info given. I suspect you left out the resulting acceleration when F2 is applied.
  • · Replies 16 ·
  • · Replies 39 ·
