Can Interferance cause magnification?
  • Context: Undergrad
  • Thread starter Thread starter pallidin
    Cause Magnification
The discussion revolves around the observation of an interference pattern created by a vinyl fence and its potential to cause magnification of the image of a back fence. Participants explore the nature of this phenomenon, questioning its commonality and the conditions under which it occurs.
  • One participant describes observing a magnified interference image of a back fence when sunlight is positioned behind the fence, noting that the image appears four times larger than the actual fence.
  • Another participant points out that the detail visible in the interference pattern is limited to the outlines of the fence and decorative elements, with no internal detail observable.
  • A participant asserts that if the phenomenon is visible to the eye, it should also be captured by a camera.
  • There is a question about whether the magnification refers specifically to the fringes of the interference pattern.
  • One participant expresses confusion about the location of the pattern and requests photographs for clarity.
  • A reference to a textbook suggests that interference patterns occur when the spacing between slits is comparable to the wavelength of electromagnetic radiation, implying a potential limitation in understanding the phenomenon.
  • A participant expresses uncertainty about whether the observed effect could be an optical illusion and plans to investigate further by observing the phenomenon on foot.
Participants do not reach a consensus on the nature of the phenomenon, with some questioning its validity as a common feature of interference patterns and others suggesting it may be an optical illusion.
Participants acknowledge the need for further investigation and clarification regarding the conditions under which the interference pattern is observed, as well as the potential for misinterpretation of the visual effect.
pallidin
There is this house down the street which has one of those new, white plastic vinyl fences around the front yard.
This particular fence is constructed in such a way as the vertical members are the width of the spacing between members(about 2 inches or so)
More importantly, the top of the fence line changes horozontaly, kind of like a wave(I suppose for aesthetic reasons) with some ornamental du-dad fashioned atop each vertical fence element.
Anyway, when I drive to work each morning, the sun is above and behind the fence.
I notice the interferance pattern, but a startling thing happens as I approach, roughly, about 100 feet from it:
A black and white interferance image of the back fence, with all the du-dads, appears with exceptional crispness and is about 4-times larger(width-wise) than the fence itself.
It is an awesome sight, an have seen it hundreds of times. It appears as though I am looking at a magnified negative image of the back fence with exquisite detail. When the sun is not behind it the image is barely noticable.
Is this a common feature of interferance patterns?
Also, if I take the time to take pictures, will the phenomenon show up?
Science news on Phys.org
I should point-out that the exceptionally fine detail I see is with respect to the outline of the back fence and top du-dads. No "non-edge" detail is observable.
Well, if your eye can see it, so can a camera...
- Warren
Do you mean magnification of the fringes (by your first topic)?
Where does the pattern appear? That's the only thing i can't follow. Sounds interesting though. Can you snap a few pictures?
I'm thinking what sporff is too [unless I misunderstood your message].
In my Serway, it says that interference patterns only occur when the spacing between the slits is approximately that of the wavelength of the EMR.
Thanks all, I've been away. I will more closely examine this to correct or further address the issue.
I am not sure that this is not some type of optical illusion or mis-interpretation on my part. Nonetheless I will endeavor to more accurately experience the event(it has previously always been by a moving car), so I will do a "walk-by" in the next week.
  • · Replies 19 ·
21K
  • · Replies 226 ·
18K
9K
  • · Replies 21 ·
