Building a Circle from 31 Panels: Calculating Circumference & Diameter
  • Context: High School
  • Thread starter Thread starter Somnabulist
    Build Circle
The discussion centers on calculating the circumference and diameter of a circle constructed from 31 panels, each 12 feet long, plus a 6-foot wide gate. The total length of the panels and gate forms a perimeter of 378 feet, which serves as the circumference of the corresponding circle. The diameter can be calculated using the formula d = C/π, where C is the circumference. Thus, the diameter of the circle is approximately 120.6 feet.
  • Understanding of basic geometry concepts, specifically circumference and diameter.
  • Familiarity with the mathematical constant π (pi).
  • Ability to perform basic arithmetic calculations.
  • Knowledge of polygon shapes and their properties.
  • Learn how to calculate the area of a circle using the formula A = π(d/2)².
  • Explore the properties of polygons and their approximation to circles.
  • Study the implications of using segments to form circular shapes in construction.
  • Investigate the mathematical principles behind constructing regular polygons.
This discussion is beneficial for students, educators, and professionals in fields such as mathematics, engineering, and construction who are interested in geometric calculations and practical applications of circular shapes.
Somnabulist
I am not a student but should become one again as I apparently did not learn enough in school. I am faced with a real world question I do not know how to answer using mathematics. Here is the problem without too much physical detail:
I need to construct a circle (rough circle) out of 31 panels that are 12 feet long. They are connectable with zero clearance. In addition is a gate that is 6 feet wide. How would I compute the diameter or the circumfrance of this circle? Is this enough data to compute an answer?
Another way to ask this is what is the circumfrance or the diameter of a circle made from a line that is 378 feet long?
Mathematics news on Phys.org
If you have a line segment that is 378 feet long and you bend it to form a circle, the circumference of the circle will be 378 feet. The diameter of a circle is given by d = C/[itex]\pi[itex], where C is the circumference.<br /> <br /> Your 31 panels plus the gate will form a 32-sided polygon that is not a circle, but is roughly circular in shape. The 378' perimeter of this figure will be approximately the same as the circumference of the corresponding circle.<br /> <br /> Is that what you're looking for?[/itex][/itex]
[itex][itex] <br /> Now this is why it is important to teach logic in school; length of line equals circumfrance of a circle made from that line. Yes, it is a 32 sided polygon in a rough circle shape. That is what I was looking for. I will be spending more time in remdial education on this website. Thanks for the taking the time to answer.[/itex][/itex]
9K
  • · Replies 96 ·
13K
  • · Replies 40 ·
  • · Replies 33 ·
