Finding the rate of change of the distance between 2 cars
The discussion focuses on calculating the rate of change of distance between two cars approaching an intersection. Car A is 0.3 km from the intersection, traveling north at 90 km/h, while Car B is 0.4 km away, traveling west at 80 km/h. The correct formula for the distance D between the two cars is derived as D = √(x² + y²). The rate of change of distance is expressed using the chain rule, resulting in the equation dD/dt = (x/C) * dx/dt + (y/C) * dy/dt. The final calculated rate of change of distance is confirmed to be 143 km/h.
  • Understanding of calculus, specifically differentiation and the chain rule.
  • Familiarity with the Pythagorean theorem in the context of distance calculation.
  • Knowledge of vector representation of motion in two dimensions.
  • Ability to interpret and manipulate rates of change in real-world scenarios.
  • Study the application of the chain rule in multivariable calculus.
  • Learn about related rates problems in calculus.
  • Explore the geometric interpretation of derivatives in the context of motion.
  • Investigate the use of partial derivatives in physics and engineering applications.
Students studying calculus, particularly those focusing on related rates and motion problems, as well as educators seeking to enhance their teaching methods in these topics.
tnutty
Car A is traveling north on Highway 16 and car B is traveling west on Highway 83. Each car is approaching the intersection of these highways. At a certain moment, car A is 0.3 km from the intersection and traveling at 90km/h while car B is 0.4km from the intersection and traveling at 80km/h. How fast is the distance between the cars changing at that moment?
Attempt :
D = sqrt(x^2 + y ^ 2)
Let C = sqrt(x^2 + y^2);
d(D) = dD/dx dx + dD/dy dy
= x/C dx + y/C dy
we are given x = 0.3, y = 0.4 , dx = 90 and dy = 80, so
d(D) = dx/6 + 8dy/5;
Now just plug in dx and y ,
so the answer I got is 143 .
Can you check this?
Attempt :
I think i see what you are trying to do, but i think its poor notation, be explicit in variables if confused
let the distance between the 2 cars, D, be exressed in terms of their distances form the intersection, x,y
[tex]D(x,y) = \sqrt{x^2 + y^2}[/tex]
then at the point in time when x = 0.3, y = 0.4, then you let
[tex]C = D(0.3,0,4)[/tex]
i don't think there is a real need for C and its a little confusing...
= x/C dx + y/C dy
this the small change formula, change in D for a small change in x & y - though you need to show how you got to the next step (the differentiation)
that said it should be in form of the partial derivatives of D wrt x & y, and you might as well relate it directly to the rate of cahnge with time of D, which is what you want at the end of the day ie.
[tex]\frac{d D(x,y)}{dt} = \frac{\partial D(x,y)}{\partial x}\frac{dx}{dt} +\frac{\partial D(x,y)}{\partial y}\frac{dy}{dt}[/tex]
this is true for all values, not just at C = D(0.3,0.4)
these dx & dys are not small changes - so even if it gives you the corrcet answer (whih I'm not sure of) you should probably format it as given above
ALso as x,y are the sides of a triangle, tey are decreasing in length
[tex]\frac{d x}{dt} = -90km/hr, \frac{d x}{dt} = -80km/hr,[/tex]
Can you check this?
and finally what are your units?
  • · Replies 20 ·
