LeGrange multiplier with inequality
  • Thread starter Thread starter memish
    Inequality
The discussion centers on applying the Lagrange multiplier method to maximize the volume of a box under the constraint of a perimeter limit. The function defined is f(x,y,z) = xyz, with the constraint given as 2x + 2z < 108. The user struggles with the implications of the equation xz = 0, leading to confusion about potential solutions and the feasibility of achieving maximum volume. The conclusion suggests that the problem may be misphrased, as the volume could theoretically increase indefinitely if y is allowed to grow without bounds.
  • Understanding of Lagrange multipliers in optimization problems
  • Familiarity with multivariable calculus concepts
  • Knowledge of constraints in mathematical optimization
  • Ability to analyze inequalities and their implications
  • Study the application of Lagrange multipliers with inequality constraints
  • Explore examples of maximizing volume under various geometric constraints
  • Learn about the implications of setting variables to zero in optimization problems
  • Investigate how to correctly formulate optimization problems to avoid misinterpretation
Students in calculus, mathematicians focusing on optimization, and educators teaching multivariable calculus concepts will benefit from this discussion.
memish
Find the dimensions of the box with the largest volume, given the constraint that the perimeter of the cross sector perpendicular to length is at msot 108
So I have f(x,y,z)=xyz
and the constraint is 2x+2z<108
I set up the legrange multipler <yz, xz, xy>=(multiplier)<2, 0, 2>
So then you have
yz=2(multiplier)
yx=2(multiplier)
xz=0(multiplier)
and then 2x+2z<108
But since xz=0(m), I can't figure out how to solve the 4 equations to get the possible points. If I have xz=0, then either x or z is 0, right? but then there would be no volume..any ideas? Thanks!
You probably have the problem stated incorrectly. As stated, the volume has no max because you could take y as large as you want no matter what x and z are.
Re-read the problem. My guess is that it will say something like "the length of the box plus the perimeter" is bounded.
  • · Replies 16 ·
  • · Replies 28 ·
