Do Adults and Children Swing at the Same Frequency?
The discussion revolves around the comparison of the swinging frequencies of an adult and a child on identical swings, focusing on the relationship between mass and the period of swing motion. The subject area includes concepts from mechanics, specifically pendulum motion and oscillatory systems.
  • Participants explore the relationship between mass and swing frequency, with some suggesting that increased mass leads to a longer period. Others reference the period of a pendulum and question the relevance of mass in determining the period.
The discussion is ongoing, with participants expressing differing opinions on the correct answer to the problem. Some have provided reasoning based on established equations, while others question the assumptions made regarding the type of pendulum being considered. There is no explicit consensus, but various interpretations are being explored.
Participants are discussing the implications of mass on the period of a swing, with references to both pendulum and spring systems. There is uncertainty regarding the applicability of certain equations to the scenario presented.
SAT2400
URGENT//Period and frequency question
1) An adult and a child are sitting on adjacent identical swings. Once they get moving, the adult, by comparison to the child, will necessarily swing with
a) a much greater period
b) a much greater frequency
c) the same period
d) the same amplitude
T= 2pi(square root of m/k)
THe answer is a B... Can anyone explain why?? I think it's an A b/c as m increases, the T increases??!
I recall the following:
For small angles of excursion (i.e. for cases when the pendulum is gently swinging over a few degrees) the period of a pendulum approximates: t = 2*pi*(sqrt(l/g)). There is no term in this equation for mass, which in itself suggests that the size of the swinging mass is not important in determining the period. (l is length of pendulum, g is acceleration due to gravity)
As for the amplitude of the swinging, this has to do with the amount of force used to start the swinging. If the adult is twice the mass of the child, then for the same amplitude of swinging twice as much force (F=m.a) is required.
Thank you for the reply...
The answer is B. Do you agree with this??
Some of my classmates think it's a C...
Could you please explain again why the answer is a B??
Thank you very much T_T
well, I'm a bit worried about the relation you have given for the period of the pendulum. Are you quite sure it's a swinging. non-elastic pendulum?
I suggest the following: take a short length of string and try the period of different masses.
You'll find that mass of pendulum makes no observable difference to the period. But there is what looks like a mass term in the relation you have given, and I wonder why. This leads me to worry that I haven't seen the whole picture. I don't want to get this wrong...
I wonder where you got the relation T=2pi(m/k)^(1/2) from?
That's the period of a spring-and-mass. Look up the period of a pendulum .
