Non conservative electric field and kirchoff law
The discussion centers around the application of Kirchhoff's laws in circuits that include inductors, particularly focusing on the nature of the electric field within inductors and its implications for circuit analysis. Participants explore the relationship between non-conservative electric fields and Kirchhoff's voltage law (KVL).
  • Some participants question whether Kirchhoff's laws can be applied in circuits with inductors due to the non-conservative nature of the electric field inside inductors.
  • Others argue that Kirchhoff's voltage law can still be used, citing that the potential difference can be calculated despite the non-conservative field, using the integral of the electric field along a loop.
  • One participant mentions that the voltage across an inductor can be expressed as V = L (dI/dt) or using complex impedance, suggesting that the internal behavior of the inductor does not invalidate Kirchhoff's laws.
  • There is a discussion about the implications of non-conservative fields on energy conservation and whether this affects the validity of Kirchhoff's laws.
  • Some participants highlight that the current law remains valid, emphasizing the necessity of charge conservation at nodes.
  • Areas of Agreement / Disagreement
    Participants express differing views on the applicability of Kirchhoff's laws in the context of non-conservative electric fields, indicating that the discussion remains unresolved with multiple competing perspectives.
    Participants note that the relationship between the electric field and potential in non-conservative systems may complicate the application of Kirchhoff's voltage law, but do not reach a consensus on the implications of this complexity.
phymatter
in circuits involving inductors can we use kirchhoff law ?
i have seen this in many books but the electric field inside inductors is non conservative !
if the direction of assumed current is opposite to the direction of motion, the voltage across the inductor rises.
i'm unable to get ur point regarding the relation between KVL and electric field :)
Welcome to PF!
Hi phymatter! Welcome to PF! :smile:
(two h's in Kirchhoff! :wink:)
Yes, V = IZ, or Vrms = Irms|Z| where Z is the (complex) impedance of the inductor.
And Z = iωL where ω is the frequency of the current, and L is the inductance, and i = √(-1).
(does it matter what's going on inside the inductor? … you'll only be measuring the voltage drop across it :wink:)
Yes you can. you can use [tex]V = L \frac {dI}{dt}[/tex] for the potential across the inductor, or you can use an impedance of [itex]j \omega L[/itex] if you can work with complex impedances and frequencies.
That the field is nonconservative is not a problem. Even if conservation of energy is violated (because of a non-closed system) Kirchhofs laws are still valid.
The current law says that all currents going into a node must sum to 0, because otherwise the electric charge will pile up.
You might think that the voltage law is not valid, because in a non-conservative electric field you can't define a potential. The potential difference if you put an open loop of wire in this field is
still the integral of the electric field along this loop however.
If you connect one side of the loop to a point with a known potential you can compute the
potential of any point of the wire.
Kirchhof voltage law tells us that for a circuit that goes through nodes A,B,C and D:
[tex](V_B - V_A) + (V_C - V_B) + (V_D - V_C) + (V_A - V_D) = 0[/tex] you can prove this
with only arithmetic using no properties of the electric field.
  • · Replies 25 ·
