Thread Closed
Defining a Lagrangian in an rotating reference frame frame
Share Thread Thread Tools
Oct21-09, 05:16 AM   #1
Hi
I'm trying to define a Newtonian lagrangian in an
rotating reference frame (with no potential)
Something to note is that the time derivative of in a rotating reference frame must be corrected for by:
[tex] \frac{d {\bf B}}{dt} \rightarrow \frac{d {\bf B}}{dt} + {\bf \omega} \times {\bf B}[/tex]
where B is some vector, this can be found in wikipedia
Therefore I get something like
[tex]L = \frac{1}{2} m(\dot{{\bf x}}+{\bf \omega} \times {\bf x})^2[/tex]
where the dot is the time derivative
and Im expecting to get three ficticious forces: Centrifugal, centripetal and euler forces.
but this does not appear what am I doing wrong?
I believe the answer should be
[tex] m(\ddot{{\bf x}}+2{\bf \omega} \times \dot{{\bf x}}+\dot{{\bf \omega}} \times {\bf x}+{\bf\omega \times (\omega} \times {\bf x}))=0[/tex]
I get this by taking the newtonian lagrangian in a non rotating frame and calculating the euler lagrange equations of motion, and then transforming into the rotating frame. but the two results do not agree?
any help would be greatly appreciated
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Oct21-09, 05:57 AM   #2
What is the equation of motion that you're getting?
Oct21-09, 07:02 AM   #3
This is the equation of motion I'm getting is:
[tex] m(\ddot{{\bf x}}+2{\bf \omega} \times \dot{{\bf x}}+\dot{{\bf \omega}} \times {\bf x}+{\bf\omega \times (\omega} \times {\bf x}))+m {\bf \omega} \times(\dot{{\bf x}}+{\bf \omega} \times {\bf x})=0[/tex]
thanks
M
Oct22-09, 12:40 AM   #4
Ive work it out
the temporal derivative is the ordinary temporal derivative not the corrected one because this is the velocity which is already defined in the rotating frame of reference
thanks again
M
Oct22-09, 12:55 AM   #5
I think ive work it out:
the temporal derivative is the ordinary temporal derivative not the corrected one because this is the velocity which is already defined in the rotating frame of reference.
now this gives the correct equations of motion
Now if I choose an arbitrary frame of reference i.e. one that is rotating and translating
this does not work, i.e. if I choose a lagrangian:
[tex]L = \frac{1}{2} m(\dot{{\bf x}}+{\bf \omega} \times {\bf x}+\tau)^2[/tex]
but this does not work.
I think this is because the translation term [tex]\tau[/tex] is an object that does not transform like the coordinates x when in a rotating frame... The correct result should be the original plus
[tex]\ddot{\tau}[/tex]
should there be a lagrangian for such a frame?
cheers
M
Thread Closed
Thread Tools
Similar Threads for: Defining a Lagrangian in an rotating reference frame frame
Thread Forum Replies
Is a uniformly rotating reference system an inertial frame? General Physics 0
Centrifugal force in rotating frame of reference Classical Physics 6
