Solving a Differential Equation: Finding the Particular Solution
The discussion focuses on finding the particular solution to the differential equation (-21/4)y'' + 2y' + y = 4xe^(3x). The user initially selected the trial function yp = (Ax + B)e^(3x) but encountered errors in calculating the derivatives. The correct approach involves recognizing that the trial function is a product, which requires the application of the product rule for differentiation. The user ultimately needs to ensure that the derivatives are computed accurately to derive the correct coefficients for A and B.
  • Understanding of differential equations and their solutions
  • Familiarity with the method of undetermined coefficients
  • Knowledge of product rule in calculus for differentiation
  • Basic concepts of homogeneous and particular solutions
  • Review the method of undetermined coefficients for solving differential equations
  • Practice applying the product rule in differentiation with various functions
  • Study the characteristics of homogeneous solutions in differential equations
  • Explore examples of finding particular solutions for different forms of non-homogeneous equations
Students and professionals in mathematics, engineering, or physics who are solving differential equations, particularly those interested in mastering the method of undetermined coefficients and product differentiation.
mansfin
I have to find the particular solution to the differential equation:
(-21/4)y''+2y'+y=4xe^(3x)
First, I chose my trial function to be yp=(Ax+B)*e^(3x). Is this correct?
so yp'=3(Ax+B)*e^(3x)
yp''=9(Ax+B)*e^(3x)
So I plug these into the differential equation and I get:
(-189/4)Axe^(3x)-(189/4)Be^(3x)+6Axe^(3x)+6Be^(3x)+Axe^(3x)+Be^(3x)=4xe^(3x)
I group like terms and I get A=-16/161 and B=0
So yp=(-16/161)Axe^(3x)
This is not correct.
Can someone please tell me where I'm going wrong? Thanks!
yp''=9(Ax+B)*e^(3x)
The particular solution you choose is affected by the solutions to the homogeneous equation. For your problem, I'm going to guess that e3x is not a solution to the homogeneous problem, but I don't know that for a fact.
In any case, and assuming that y = e3x is not a solution to the homogeneous problem, your choice for a particular solution is good, but you made a mistake in both of your derivatives. differentiation. =(Ax+B)*e3x is a product, a fact that you seem to have completely overlooked.
Wow. Implied multiplication on my calculator. Next time I will just work that out by hand. Thanks for your help!
  • · Replies 25 ·
  • · Replies 24 ·
  • · Replies 52 ·
10K
