How to properly find the Domain of fog/gof ?
  • Thread starter Thread starter Spiffy
    Domain
The problem involves finding the compositions of two functions, f(x) = x + 1 and g(x) = x², along with determining their respective domains. The original poster seeks clarification on how to properly identify the domains of the compositions g o f and f o g.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the need to consider the range of the first function in relation to the domain of the second function when composing them. There are attempts to express the domains of the compositions using inequalities and to clarify the relationship between the functions' domains and ranges.
There is an ongoing exploration of how to correctly identify the domains of the compositions. Some participants provide insights into the necessary conditions for the compositions to be defined, while others express uncertainty about the explanations and seek further clarification.
Participants note the importance of adhering to the defined domains of the original functions and the implications of those domains on the compositions. There is mention of the need for formal notation and clarity in expressing the reasoning behind the domain restrictions.
Spiffy
f(x) = x + 1 D=[-9, 9]
g(x) = x2 D=(1, 5)
Question to be solved
Find both g o f and f o g and specify their domains
The attempt at a solution
g o f = (x+1)2
This is where I don't really know what to do, however I'll let the logical part of my brain go a bit silly and try this:
d= {x e R | 1 < x <= 2} because I'm making the assumption that it has to be true of both domains so while x = -4 would satisfy the domain of f(x) it doesn't g(x). Is that right? If so: how do I show this with math and not just my brain.. I think its inequalities but I've never been good at those, a first step would be much appreciated.
f o g = x2 + 1
well x must be >1 but then I need to find whatever value is x2 + 1 < 9
maybe
sqrt(8) ? also, as sqrt(8) is clearly < 5 it fits the criteria i think are necessary
So if I'm correct above it means D{x e R | 1 < x <= sqrt(8)}
I'm mostly sure I've answered these correctly, but I'm missing the formal way I should be writing this; the last thing I want is marks for correctness and marks lost for not showing my work.
Thanks to anyone that points me in the right direction.
i can;t quiet follow what you've done, but you need the range or image of the intermediate function vs the domain of the 2nd function
so with som sloppy notation
g(f(x)): x -> f(x) -> g(x)
now the domain of f is [-9,9], only values of f(x) that fall into (1,5) can be taken by g, so how does this limit the values you can take from [-9,9]
ie. the domain of g(f(x)) must satisfy both x in [-9,9] and f(x) = x+1 in (1,5)
then similar for f(g(x))
When you are composing two partial functions, the "is in the domain" relation can be computed by:
x is in the domain of gof iff x is in the domain of f and f(x) is in the domain of g​
Both of the things on the right-hand-side of that iff can be written as inequations, and you know how to solve those, right?
Okay I'm still not sure with the explanations provided but I'll give it a shot:
This is the line I'm basing what I've done on:
"you need the range or image of the intermediate function vs the domain of the 2nd function"
and I'm thinking about the functions as:
where:
g(x) = x2 D=(1, 5)
and:
g o f = (f(x))2
and
f o g = g(x) + 1
then:
g o f = (x+1)2
D = (1, 5)
The possible values for f(x) (aka: the range) is [-8, 10] which fails to affect the domain of g
f o g = x2 + 1
D = (1, 9]
The range of g(x) is 1<x<25 limiting the possible Domain of f(x) as it has to be >1
I hope this is right because it makes sense to me from a logical perspective, if it is I'll chalk this up to another situation of over-thinking.
so for the functions, the domain & images are:
[tex]x \rightarrow f(x) = x+1[/tex]
[-9,9] -> [-8,10]
[tex]x \rightarrow g(x) = x^2[tex] (1,5) -> (1,25)<br /> <br /> notice they are both one to one on the given domian which simplifies things<br /> <br /> now for the function gof(x), the image, f([-9,9]) = [-8,10], but g(x) can only take values on (1,5) so we must restrict the domain, otherwise g is undefined, so we look at the f pre-image of the g domain, <br /> [tex]f^{-1}(x) = x-1[/tex]<br /> [tex]f^{-1}((1,5)) = (0,4)[/tex]<br /> <br /> so the total doamin will be given by the intersection of the f pre-image of the g domain & and the f domain <br /> [tex]D_{gof} = D_f \cap f^{-1}(D_g) = [-9,9] \cap (0,4)[/tex] <br /> <br /> if all this is confusing try drawing 3 horizontal lines above each other.<br /> - the bottom is x, draw f domain<br /> - the 2nd is y = (f(x)), draw g domain <br /> - the 3rd is z = g(f(x)) <br /> now try and draw the approximate mapping action of each function between the lines[/tex][/tex]
  • · Replies 23 ·
  • · Replies 23 ·
