Calculating Force on Potassium Ion Due to Electric Field
The discussion focuses on calculating the force on a potassium ion (K+) due to an electric field created by charges on a cell wall. The relevant formulas include F = qE for electric force and E = kq/r^2 for electric field calculation, where k is Coulomb's constant (8.99 x 10^9 Nm^2/C^2). The potassium ion's charge is 1.60 x 10^-19 C, and the total charge on the cell wall is 1.00 x 10^-15 C. The problem is solved by calculating the electric field at distances of 2.70, 2.92, and 4.00 micro-meters from the center of the cell, followed by determining the force on the potassium ion at each distance.
  • Understanding of electric force and electric field concepts
  • Familiarity with Coulomb's constant (8.99 x 10^9 Nm^2/C^2)
  • Knowledge of charge units (Coulombs)
  • Ability to perform unit conversions (e.g., micro-meters to meters)
  • Learn about electric field calculations for point charges
  • Study the implications of charge distribution on electric fields
  • Explore the concept of electric force in different mediums
  • Investigate the behavior of ions in electric fields
Students in physics, electrical engineers, and anyone interested in electrostatics and the behavior of ions in electric fields.
thebigbluedeamon
If someone could help me start this problem, it would be greatly appreciated.
Charges of equal magnitude 1.00X10^-15 C and opposite sign are distributed over the inner and outer surfaces of the cell wall. Find the force on the potassium ion (K+) if the ion is, (a) 2.70 micro-meters from the center of the cell, (b) 2.92 micro-meters from the center, and (c) 4.00 micro-meters from the center.
I suspect that I'm going to use F=qE but I'm not quite sure.
What size are the inner and outter surfaces of the cell wall? Are the charges distributed uniformly?
I guess that you have to calculate the electric field, but the electric field depends on the cell wall.
Sure, I can help you get started on this problem. First, let's review the formula for electric force, which is F = qE. Here, q represents the charge of the particle and E represents the electric field. In this problem, we are looking for the force on a potassium ion (K+) due to the electric field created by the charges on the cell wall.
To solve this problem, we will need to calculate the electric field at each distance from the center of the cell. The electric field created by a point charge can be calculated using the formula E = kq/r^2, where k is the Coulomb's constant (8.99 x 10^9 Nm^2/C^2), q is the charge of the point charge, and r is the distance from the point charge.
For part (a), the potassium ion is 2.70 micro-meters from the center of the cell. First, we need to convert this distance to meters, which is 2.70 x 10^-6 m. Then, we can calculate the electric field at this distance by using the formula E = kq/r^2, where q is the total charge on the cell wall (1.00 x 10^-15 C) and r is the distance from the center (2.70 x 10^-6 m). This will give us the magnitude of the electric field at this distance.
Once we have the electric field, we can use the formula F = qE to calculate the force on the potassium ion. Remember, q represents the charge of the particle, which is the charge of the potassium ion (1.60 x 10^-19 C). So, the force on the potassium ion at this distance would be F = (1.60 x 10^-19 C)(electric field at 2.70 x 10^-6 m).
You can follow the same steps for parts (b) and (c), using the respective distances and calculating the electric field at each distance. Just remember to convert all distances to meters before plugging them into the formulas. I hope this helps you get started on the problem. Good luck!
10K
  • · Replies 23 ·
