I am doing a project analysis and need some help with errors
This discussion focuses on the analysis of experimental data obtained from measuring the width of a waveguide using microwaves and standing waves. The resulting linear graph, represented by the formula y = 1.0741x + 455.08 with an R² value of 0.9979, allowed for the calculation of the waveguide width as 2.34e^-2m. The user seeks assistance in determining the error in the experimental value, which is influenced by the accuracy of the slope of the graph. The discussion emphasizes the application of Gauss' error laws and the use of regression analysis tools, such as those available in MS Excel, to derive the necessary error metrics.
  • Understanding of waveguide theory and standing wave patterns
  • Familiarity with linear regression analysis
  • Knowledge of Gauss' error propagation laws
  • Experience using MS Excel for data analysis
  • Study the application of Gauss' error propagation laws in experimental physics
  • Learn how to perform linear regression analysis using MS Excel
  • Explore advanced error analysis techniques in experimental data
  • Investigate the impact of measurement uncertainty on experimental results
Physics students, experimental researchers, and data analysts involved in waveguide measurements and error analysis in scientific experiments.
foxen
Basically, I have used microwaves in a wave guide to measure the width of the guide via standing waves. This led me to plot a graph of 1/wavelength in the guide^2 vs 1/wavelength^2 in air.
The graph showed the following formula; y = 1.0741x + 455.08 with an R^2 value of 0.9979 from 5 points.
This enabled me to calculate the width of the guide using the following formula; 1/2*width^2 = c. which came out as 2.34e^-2m.
So far a very good result, as when I measured the guide it had a width of
2.3e-2m +/- 0.05e^-2.
The problem is that I now need to work out the error in my experimental value of a. Which is obviously a product of the accuracy of the slope of the graph. How should I proceed? Any help would be appreciated.
You need Gauss' error laws:
Given a formula [tex]z=x^{\pm a}[/tex] ([tex]a[/tex] a constant) then the error in [tex]z[/tex] is [tex]\frac{\Delta z}{z}= |a|\frac{\Delta x}{x}[/tex]
and given a formula [tex]z=b.x[/tex] ([tex]b[/tex] a constant) then the error in [tex]z[/tex] is [tex]z=a.\Delta x[/tex]
You can combine both of those to get the error. To get the error in the slope and x-intercept in your graph (provided you've added some kind of linear trendline to it) then you need to use a regression package (one comes as standard with MS Excel) and that will give you the data you need.
  • · Replies 18 ·
