Convert 110 house current to 12 v.
  • Thread starter Thread starter Bits
    Convert Current
The discussion centers on using a Super Winch 12 Volt LP 8500 with a household inverter. The winch motor operates at 12 volts, drawing 4.5 hp and 3.3 kW, which translates to approximately 275 amps at 12 volts. Users suggest that powering this winch continuously from a household circuit is impractical; however, using a bank of car batteries combined with a high-capacity charger, such as the IOTA DLS1290, can provide a feasible solution for intermittent use.
  • Understanding of inverter specifications and capabilities
  • Knowledge of battery capacity and charging systems
  • Familiarity with electrical current calculations (amps, volts, watts)
  • Experience with automotive battery configurations
  • Research high-capacity inverters suitable for 12V applications
  • Learn about battery bank configurations for optimal performance
  • Investigate the IOTA DLS1290 charger and its specifications
  • Explore safety measures for high-current electrical setups
This discussion is beneficial for DIY enthusiasts, electricians, and anyone looking to operate high-power 12V devices from household current without relying on a vehicle alternator.
Bits
I have a super winch 12 volt LP 8500 that I want to use using an inverter from my household current. The motor is 12volt 4.5 hp 3.3 kw.
I have tried to use a battery with my battery charger but the battery does not hold enough charge without have a vehicle that has an alternator.
Is there a good inverter that would allow me to use this winch without having to use a truck.
Thanks,
Bits
Thanks,
Bits
3.3kW is 30 Amps at 110Vrms. That's near the limit for a house branch circuit...
  • · Replies 27 ·
