Modulation: Why 455kHz is the IF Frequency
  • Thread starter Thread starter oufa
    Modulation
The discussion centers on the implications of having a signal at the Intermediate Frequency (IF) of 455 kHz in AM radio systems. It is established that a strong signal at this frequency can cause interference with the intended reception, leading to degraded performance. The choice of 455 kHz as an IF frequency is not arbitrary; it is selected based on receiver design and the desired receiving band. Other IF frequencies, such as 10.7 MHz for FM receivers, are also noted as alternatives depending on specific requirements.
  • Understanding of Intermediate Frequency (IF) in radio communications
  • Knowledge of AM and FM modulation techniques
  • Familiarity with signal interference concepts
  • Basic principles of radio receiver design
  • Research the role of IF frequencies in radio receiver design
  • Learn about signal interference and its impact on radio communications
  • Explore different IF frequencies used in various modulation schemes
  • Investigate the design considerations for AM and FM receivers
Radio engineers, communication system designers, and anyone involved in the development or optimization of AM and FM radio receivers will benefit from this discussion.
oufa
why it is disaster if asignal exists in am at frequency of 455 khz , i mean asignal is at the IF frequency.
also why IF not greater or smaller than 455khz i need to know
thanks
thanks
Your question is not clear. Please try again with more details and more context. Thanks.
This should be obvious. If the signal is strong enough to enter the IF amplifiers then it will cause interference by coexisting with the signal you are trying to receive.
thanks
455khz is not the only IF frequency. Other frequencies are used depending on the receiver design, desired receiving band, and number of conversions. For example, 10.7mhz is a common IF for the FM broadcast band receiver.
  • · Replies 39 ·
