Maximum Angle of Elevation for Lighthouse Light?
  • Thread starter Thread starter undrcvrbro
    Angle Maximum
The maximum angle of elevation for a lighthouse light, which is tilted at 7 degrees when pointing east and 2 degrees when pointing north, is calculated using trigonometric principles. The correct maximum angle of elevation is determined to be approximately 7.28 degrees, derived from the equations involving cosine functions and the angles of elevation at specified directions. The initial calculation of 66 degrees was incorrect due to a misunderstanding of the relationship between the angles and their periodic nature. The discussion highlights the importance of accurately applying trigonometric identities in solving elevation problems.
  • Understanding of trigonometric functions, specifically cosine and tangent.
  • Familiarity with calculus concepts such as gradients and slopes.
  • Knowledge of periodic functions and their properties.
  • Basic proficiency in solving equations involving angles and elevation.
  • Study the derivation of maximum elevation angles using trigonometric identities.
  • Learn about the application of gradients in multivariable calculus.
  • Research periodic functions and their implications in real-world scenarios.
  • Explore advanced trigonometric problem-solving techniques for elevation and slope calculations.
Mathematics students, physics enthusiasts, and engineers involved in projects related to optics, elevation calculations, and lighthouse design will benefit from this discussion.
undrcvrbro
The axis of a light in a lighthouse is tilted. When the light points east, it is inclined upward at 7 degree(s). When it points north, it is inclined upward at 2 degree(s). What is its maximum angle of elevation?
Duf(0, 0) = gra.f(0, 0)* u
and the maximum slope will be
grad. f(0, 0) = sqrt(fx(0, 0)^2 + (fy(0, 0)^2))
fx(0, 0) = tan 9; fy(0,0)= tan2
And therefore
abs(grad. f(0, 0)) = ((tan9)^2 + (tan2)^2)
The maximum elevation is therefore given by
arctan ((tan 9)^2 + (tan2)^2) = 66 degrees
For some reason my final answer is wrong. Any idea where I made a mistake?
I really have no idea what you are doing there. Why would the maximum slope be given by "grad. f(0, 0) = sqrt(fx(0, 0)^2 + (fy(0, 0)^2))"? What is f?
I certainly don't see how, from knowing the elevation at two directions, ninety degrees apart, are "2" and "9" you get "66" for the maximum! It's not too difficult to see that, if we take [itex]\theta[/itex] as the maximum angle of elevation and measure [itex]\phi[/itex] around the circle from the direction of elevation, the angle of elevation in direction [itex]\phi[/itex] is periodice with period [itex]2\pi[/itex], starts at [itex]\theta[/itex], is 0 at [itex]\phi= \pi/2[/itex], [itex]-\theta[/itex] at [itex]\phi= \pi[/itex], 0 againat [itex]\phi= 3\pi/2[/itex] and [itex]\theta[/itex] again at [itex]\phi= 2\pi[/itex].
In other words the elevation at angle [itex]\phi[/itex] is [itex]\theta cos(\phi)[/itex].
Let [itex]\phi_0[/itex] be the angle corresponding to "east". Then [itex]\theta cos(\phi_0)= 7[/itex]. "North" will now be [itex]\phi_0+ \pi/2[/itex] so [itex]\theta cos(\phi_0+ \pi/2)= 2[/itex].
Solve those equations for [itex]\theta[/itex].
I think saying that "elevation at angle [tex]\phi[/tex] is [itex]\theta cos(\phi)[itex]" is a very good assumption but not exactly correct. I encountered a very similar problem some time ago and I think the correct method is a little different. It is close to a cosine curve but not exactly<br /> <br /> Doing it your way Hallsoflvy, I get 7.280109 degrees. Doing it my way, I get 7.282863 degrees. Do you have the answer to that many significant digits undrcvrbro? If what I got is correct, I'll explain what you need to do.<br /> <br /> PS: I can't get my quote and some latex to work properly. Sorry..[/itex][/itex]
