What are some recommended transceiver models for Bluetooth tracking devices?
The discussion centers on selecting suitable Bluetooth transceiver models for designing devices that alert users when they come within 1 meter of each other. The user seeks a solution that operates effectively through obstructions and from various angles, with a budget of approximately £30 ($50) for a pair of transceiver chips. Bluetooth technology is identified as the most appropriate for this application, with an emphasis on models that can achieve a practical range of up to 100 meters for real-world usage.
  • Understanding of Bluetooth Low Energy (BLE) technology
  • Familiarity with circuit design and prototyping
  • Knowledge of RF (Radio Frequency) communication principles
  • Experience with microcontroller programming for device integration
  • Research specific Bluetooth transceiver models such as the Nordic Semiconductor nRF52 series
  • Explore circuit design techniques for Bluetooth-enabled devices
  • Learn about Bluetooth range optimization methods
  • Investigate microcontroller options compatible with Bluetooth transceivers, such as the Arduino Nano 33 BLE
This discussion is beneficial for hardware developers, electronics engineers, and hobbyists interested in creating Bluetooth tracking devices and enhancing proximity alert systems.
jeff1664
Hi,
I'm looking to design and build two circuits for devices that will alert the two holders of the devices when they come within 1m of each other (I only need 1m range for demonstrations of the devices – in practice, the range will be more like 100m).
Now I'm pretty sure Bluetooth technology is the best suited for the task but I'm very new to using Bluetooth so am open to other suggestions - I need the devices to work from any angle and also ‘through’ obstructions blocking direct vision between the devices.
If I’ve not made sense so far, picture this: you are on a train heading home but are unaware a friend of yours is also on the same train. A device to let you know your friend is nearby could be quite handy at this point (of course, your friend would need to be carrying a similar device!)
I’m able to spend approx £30 ($50) on a pair of transceiver chips.
Can anyone suggest a transceiver model that would suite my needs?
I hope I’ve given enough information
Thanks
  • · Replies 0 ·
