How Does Earth's Rotation Affect Projectile Trajectory Calculations?
The discussion centers on the impact of Earth's rotation on projectile trajectory calculations, specifically addressing the validity of the potential energy equation mgh at varying heights. It is established that while mgh is applicable at heights below 1000m where changes in gravitational acceleration (g) are negligible, a more general expression for gravitational potential energy is Ug = -G*m1*m2/r. Additionally, when launching a projectile at an angle, an extra kinetic energy term, -\frac12 m(\omega\times \vec{r})^2, must be included to account for Earth's rotation and varying tangential velocity based on geographic location.
  • Understanding of gravitational potential energy and its equation (mgh)
  • Familiarity with the general expression for gravitational potential energy (Ug = -G*m1*m2/r)
  • Knowledge of kinetic energy concepts and equations
  • Basic principles of Earth's rotation and tangential velocity
  • Research the implications of varying gravitational acceleration at different altitudes
  • Study the effects of Earth's rotation on projectile motion using advanced physics simulations
  • Learn about the Coriolis effect and its influence on trajectory calculations
  • Explore the mathematical derivation of kinetic energy adjustments due to rotational motion
Physics students, aerospace engineers, and anyone involved in projectile motion analysis or related fields will benefit from this discussion.
holtvg
Is the potential energy equation technically invalid as potential energy is defined as mgh but as h changes g changes, so if i launched a projectile at 2000 m/s straight up or 90 degrees, how high would it go. Guess the change in g is negligible at heights below 1000m. So technically the exact potential energy of an object is not mgh.
What if you launched the projectile at an angle other than 90 degrees, how would you account for the rotation of the Earth aka the tangential velocity, not to mention the tangential velocity is different depending on where you are as the radius is different.
:confused:
You're right...mgh applies for when changes in g are negligible. There is a more general expression -- Ug = -G*m1*m2/r.
:confused:
The expression for the potential energy doesn't change and is given in the previous post.
You are right, for the kinetic energy one has to add an extra term [itex]-\frac12 m(\omega\times \vec{r})^2[/itex] due to the rotation of the earth, where r is the position on the Earth see from the center.
  • · Replies 16 ·
10K
  • · Replies 34 ·
