Elevator controller design project
The discussion focuses on designing a controller for a two-floor elevator system, utilizing a single button for operation. The elevator features reversible motor functionality, limit switches to prevent damage, and indicator lights to show the current floor status. The implementation of SR latches for door control is a key challenge, with suggestions for using mechanical switches or photo cells to enhance functionality. A block diagram is recommended to visualize the system components and their interactions.
  • Understanding of elevator control systems
  • Knowledge of SR latches and their applications
  • Familiarity with limit switches and their functions
  • Basic principles of reversible motors
  • Research the implementation of SR latches in elevator systems
  • Study the design and function of limit switches in mechanical systems
  • Explore the use of mechanical switches and photo cells in automation
  • Learn about block diagram creation for control system design
Engineering students, hobbyists designing automation projects, and professionals involved in elevator system design and control.
Nyasha
I am designing a controller for an elevator. The elevator can be at one of two floors: Ground or First. There is one button that controls the elevator, and it has two values: Up or Down. Also, there are two lights in the elevator that indicate the current floor: Red for Ground, and Green for First. I am stuck on how do l add the SR latches which open and close the door when it reaches the desired elevator floor ?
This is obviously coursework. Have you drawn up a block diagram of what you need to include?
A lot of this would be done with mechanical switches or photo cells.
The motor has to be reversible so the elevator can go up or down.
There must be limit switches at the top and bottom of the travel to stop it hitting the roof or the ground.
Since there are only two floors, an UP/DOWN choice of buttons seems unnecessary.
If you are on one floor there is only one place to go. Just one button would be needed.
When the elevator arrives at a floor, it should open the door of that floor.
When it is about to depart, it should close the door.
Lights etc are switched by the presence of the elevator at the floor.
Thanks for the help !
  • · Replies 17 ·
  • · Replies 42 ·
  • · Replies 26 ·
