Integral Using Residue Theorem?
The problem involves evaluating the integral of 1/(1+x^4) from negative infinity to positive infinity using the residue theorem, a concept from complex analysis.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to identify the singularities of the function and calculate residues at specific points, expressing confusion over obtaining a complex number as a result.
  • Some participants question the completeness of the singularity identification and suggest alternative methods for finding singularities using polar coordinates.
  • Others raise concerns about the uniqueness of certain solutions and the implications for the residue calculation.
  • Further inquiries are made regarding the application of the residue theorem to a different integral involving sin(x^2).
The discussion is ongoing, with participants providing insights and suggestions for identifying singularities and calculating residues. There is no explicit consensus on the correctness of the original poster's approach, but multiple interpretations and methods are being explored.
Participants note the importance of identifying all singularities and the potential non-uniqueness of certain solutions, which may affect the evaluation of the integral. The original poster also expresses uncertainty about the next steps in a related problem involving sin(x^2).
yeahhyeahyeah
the integral of 1/(1+x^4) from -infinity to +infinity
Residue theorem.
1/(1+z^4) so z^4 = -1
I know I should be using the residues at z = -sqrt(i) and z= i*sqrt(i)
I am getting a complex number as an answer which makes no sense
residue at z = -sqrt(i) = 1/(4*i*sqrt(i))
and at z = i*sqrt(i) = 1/(4*sqrt(i))
and therefore integral of (1/1+z^4) = 2pi*i* sum of those residues
Am I on the right track?
This is a tricky. When else does [tex]z^4+1 =0[/tex]? Maybe at [tex]z=e^{i\frac{\pi}{4}}[/tex].
Can you get it from here?
been a while since I've done these, but as a start, rather than working with sqrt i, which i don't think is unique, I would find the singularities by first letting
[tex]z = r e^{j \theta}[/tex]
whilst for some integer n
[tex]-1 = e^{j\pi(2n+1)}[/tex]
then the singularities can be found by
[tex]z^4 = r^4 e^{j 4 \theta} = e^{j\pi(2n+1)}[/tex]
giving
[tex]\theta = \frac{\pi(2n+1)}{4} = \pi(n/2+1/4)[/tex]
which I think will give 4 unique singularities for n = 0, 1, 2, 3
OOOh, I see, I used the singularities and I get pi/sqrt2 which I think is right. Thank you guys so much. I actually have another related question now though. First of all, why does sqrt(i) not work when I use it as z?
Also,
I'm now trying to do:
integral (0 to infinity) of sin(x^2) using residue theorem as well. I can't figure out how to make the substitution.
I don't know when/if you guys will answer that question but thanks so much for your help just now!
well first you didn't find all the singularities (2 out of 4) & sqrt(i) is not unique. There are 2 unique answers, note we try and solve
[tex]z^2 = i[/tex]
so as before
[tex](e^{i \theta})^2 = e^{i 2 \theta} = e^{(2n+1)\pi}[/tex]
so the 2 solutions in the \theta range [0, 2pi) are
[tex]\theta = (n+1/2)\pi} = \pi/2, 3\pi/2[/tex]
compare it with solving
[tex]z^2 = 1[/tex]
there is a plus & minus solution
that said if i remember residues correctly, you probably only need 2 of them anyway
not too sure about your sin question, but it may be worth trying writing the sin in terms of the sum/differnce of 2 complex exponentials
giving
I agree. Except when you make the semicircle, the poles n=0, 1 are the only ones on the upper half plane.
  • · Replies 19 ·
  • · Replies 23 ·
