| Thread Closed |
Calculating work |
Share Thread | Thread Tools |
| Oct27-09, 11:58 PM | #1 |
Calculating work
There is a piano that is being lowered 5 m. It has gravity force acting in y-direction (down) of 2500 N. Then it has two ropes attached, they are vectors that are pointing up and out. so T1 is 1830N [W60[tex]\circ[/tex]N] and T2 is 1295N [E45[tex]\circ[/tex]N] 2. Relevant equations so the work by gravity is 12500 J the work by T1 is 4575 J (opposite direction to work by gravity) 3. The attempt at a solution so it would make sense that the work by T2 is somewhere close to 7000 J so that the net work is 0. but when i calculate it i get around 4000 J. Can someone check my math... For T2: W = Fcos[tex]\theta[/tex][tex]\Delta[/tex]r = 1295*cos45*(5) = 4579 J ???? - thnx! |
| Oct28-09, 02:11 AM | #2 |
Hi there,
I believe you have a problem with the angle of T1. Becausem, when I verified your calculations, I come to precisely 0 net work. Cheers |
| Oct28-09, 11:47 PM | #3 |
oh yes thank you! i was using an angle that gave the component perpendicular to motion :)
| Thread Closed |
| Thread Tools | |
Similar Threads for: Calculating work
| Calculating the Work done | Introductory Physics Homework | 2 | ||
| Calculating work | Calculus & Beyond Homework | 3 | ||
| Calculating Work | Introductory Physics Homework | 2 | ||
| Calculating Work | Calculus | 0 | ||
| Calculating Net Work | Introductory Physics Homework | 3 | ||
