Show Rationals and Integers are not Isomorphic
  • Thread starter Thread starter miqbal
    Integers
The discussion establishes that the groups \textbf{Q} (rationals) and \textbf{R} (integers) are not isomorphic under addition. Key points include the necessity of a bijective homomorphism for isomorphism, which fails due to the infinite density of rationals between any two integers. The proof demonstrates that any assumed homomorphism cannot maintain the required properties, confirming the non-isomorphic nature of these groups.
  • Understanding of group theory concepts, specifically homomorphisms and bijections.
  • Familiarity with the properties of countable and uncountable sets.
  • Knowledge of rational and integer number systems.
  • Basic understanding of proofs in abstract algebra.
  • Study the properties of homomorphisms in group theory.
  • Explore the concept of countability and its implications in set theory.
  • Learn about the structure of abelian groups and their characteristics.
  • Investigate examples of isomorphic and non-isomorphic groups in algebra.
Students of abstract algebra, mathematicians exploring group theory, and anyone interested in the properties of rational and integer number systems.
miqbal
Show that the groups [tex]\textbf{Q}[/tex] and [tex]\textbf{R}[/tex] are not isomorphic (both under addition).
This was already answered before https://www.physicsforums.com/showthread.php?t=294687", but using different theory (generators and cyclic groups). We haven't covered that stuff in class yet. See below.
Two groups, G and H, are NOT isomorphic if:
1) |G| [tex]\neq[/tex] |H|
2) Let [tex]\varphi[/tex] be a map from G to H. Then G, H are not isomorphic if for some [tex]x \in \textbf{G}, |x| \neq |\varphi(x)|[/tex]
3) G is abelian, H is not abelian or vice versa.
Two groups are isomorphic iff there exists [tex]\varphi:\textbf{G} \rightarrow \textbf{H}[/tex] s.t:
1) [tex]\varphi[/tex] is a homomorphism.
2) [tex]\varphi[/tex] is a bijection.
Homomorphism:
[tex]\varphi(xy) = \varphi(x)\varphi(y)[/tex].
I know it is possible to set up a bijection from Z to Q because Q is countable (isomorphic to N) and so is Z. Then the solution must be that no homomorphism exists from Z to Q.
Proof
p,q are rational. p < q. a,b are integers. [tex]\varphi:{\bftext{Q} \rightarrow \bftext{R}[/tex], assume it is a homomorphism.
If [tex]\varphi(p)=a, \varphi(q) = b[/tex], then [tex]\varphi(p + q)=\varphi(p)+\varphi(q) = a + b[/tex]. But consider p + (q - p)/2. This must map to an integer in between a and b. Why? (I'm not sure, i'll have to investigate this rigorously). Since there are finitely many integers between a and b, but infinitely many rationals between p and q, [tex]\varphi[/tex] cannot be bijective. Which means that there is no homomorphic map from the rationals to the integers that is also bijective. So Q cannot be isomorphic to R.
Is this sufficient?
It's a little sketchy. Let f be an isomorphism Q->Z. Let p=f^(-1)(1). Then what is f(p/2)? It must be an integer that when added to itself gives 1.
Yeah got it.
If [tex]f^{-1}(1) = p[/tex], then [tex]\varphi(\frac{p}{2}+\frac{p}{2})=1[/tex] but that implies [tex]0<\varphi(\frac{p}{2})<1[/tex] which is impossible since no integer exists between 0 and 1.
Thanks man.
  • · Replies 45 ·
  • · Replies 21 ·
