Calculating Energy to Pressure
  • Context: Graduate
  • Thread starter Thread starter JCON87
    Energy Pressure
The discussion revolves around converting energy measurements from a program used for analyzing explosive pressures into pressure values relevant for structural analysis. Participants explore the relationships between energy density, pressure, and the specific conditions of explosive materials, particularly in the context of building collapses and debris analysis.
  • One participant seeks to convert energy (in kJ/cc) to pressure, noting that pressure is related to energy density and depends on the specific heat of the gas involved.
  • Another participant mentions that the relationship between internal energy and pressure can be expressed as P = 3U/5, where U is the energy density.
  • A participant provides details about the composition of the explosive materials and their densities, along with the calculated mechanical energy of detonation.
  • Concerns are raised regarding discrepancies between calculated core pressures and those reported by experts, with one participant noting their results are significantly higher than expected.
  • Participants discuss the formula for calculating pressure drop-off with distance, with one participant expressing uncertainty about the correctness of their approach and the conditions under which pressure drop-off changes from cubic to square inverse relationships.
  • Another participant elaborates on the complexities of pressure behavior in different environments, such as open air versus enclosed spaces, and the implications of thermal non-equilibrium in explosive gases.
Participants express varying degrees of understanding and uncertainty regarding the calculations and relationships involved in converting energy to pressure. There is no consensus on the correct approach or the expected values, as discrepancies in results are noted and further clarification is sought.
Participants highlight limitations in their understanding of the original calculations and the assumptions underlying their models. There is mention of potential errors in density values and the need for further consultation with experts to clarify discrepancies.
This discussion may be useful for students and researchers involved in explosive material analysis, structural engineering, and those interested in the relationships between energy and pressure in various contexts.
JCON87
I am a student at the University of Delaware, working for the Disaster Research Center under grant from the National Science Foundation. My project has me analyzing building collapses and rubble/debris pile structure. I have been loaned a program by the Livermore Laboratory called Cheetah which calculates explosive pressures. This program has been unbelievably useful but the output for particular data is given to me in energy (Kg/cc) and I need it in a pressure form to calculate the pressures acting on the structure.
How can I convert the energy to pressure? Remember this is acting on a structure and is not contained in a specific volume other than the container that the device is located in (which disintegrates upon initial reaction) and is not moving the entire object (so calculating the amount of work being done is a no go). Thanks for any help you can give me.
Pressure is a measure of the energy density of a pressurized fluid. If you are given units of energy per unit volume (this would be KJ/cc perhaps but not Kg/cc which is simple mass density), that would be the internal energy of the gas per unit volume. The relationship between pressure and internal energy depends on the specific heat of the gas. If we are dealing with air, the Cv of air is about 5R/3 (mostly diatomic gas) where R is the gas constant. So to convert Energy density to pressure you would multiply by 3/5:
U = nCvT = 5nRT/3
PV = nRT (ideal gas equation)
So: U = 5PV/3; P = 3U/5
Note: energy is a measure of a force multiplied by the distance through which that force acts. E = Fd. Pressure is force per unit area: P = F/A = F/(V/d) = Fd/V = E/V. Pressure x volume = Energy. Pressure x change in volume represents the work done by a gas when expanding in volume.
AM
I did not see the typo, yes I have the energy in kJ/cc. When I go in tomorrow I will try to work out the calculations and see if they match up to what I expect. Thanks for your help!
I was looking through and I am still not getting what I am expecting, the issue is what I am expecting was previously calculated by experts.
What I know:
The compound is 94.5% AN (2,057kg, Density: 0.84 kg/L) and 5.5% Fuel Oil (120kg, Density: 0.86 kg/L)
This is stored in (13) 55-gallon drums
Total density = 2,177,000g (components) ÷ 2,706,569 cc (capacity of drums) = 0.804
g/cc
The velocity of detonation (VoD) is: ~3,900 meters per second
The software from the Livermore Laboratory has given me this based on those numbers: The mechanical energy of detonation = -3.345 kJ/cc
Sorry for not understanding this and thanks for any help you can provide.
(I am getting core pressures of 1.96 GPa, but that is a little more than half what experts have gotten)
I found an error in the densities so I started using those supplied by the Livermore Lab and came up with numbers that are twice what was expected. Unfortunately I do not know how the original pressure was calculated and the guy who did it is not available to explain. His core pressure is 500,000psi and I'm getting around 1 million. The other inconsistency I am getting is that the pressure from ANFO is higher than ANNM (which is more explosive).
I am consulting a former NASA physicist here at the University to see if I can figure that out. MY question now is, am I using the correct formula to calculate pressure drop off at distance x. I have this entered in an excel spreadsheet so I don't have to do hundreds of calculations.
I am using this: =SUM(A4/(B5)^3)
where A is the pressure and B is the distance. I know that pressure drop off is an inverse function of the distance cubed, and that after a certain distance it is to drop to an inverse function of the distance squared. I don't know where that magic number is but considering the structure is 10' away from the device I don't need the 2nd. Does this look correct so far? Thanks
Pressure is a function of volume and temperature. Pressure will vary inversely as the volume and directly with temperature (in Kelvin - 0 K = -273 C) in an ideal gas that is in thermal equilibrium. As the gas expands, it cools because it is doing work (ie. converting its internal energy into mechanical work). The temperature will depend on how much internal energy is converted to mechanical work. The more rapidly it performs work, the more rapidly it cools and therefore the more rapidly the pressure decreases.
For example, if the explosion takes place in open air, the exploding gases do work [itex]P_{atm}\Delta V[/itex] against the atmosphere. If the explosion is inside a building, the explosion does a lot more work in ripping apart the building. In the first case, the pressure front of the exploding gases will be higher for a given volume than in the latter case.
To further complicate matters, the exploding gases are not in thermal equilibrium - there will be a temperature gradient within the exploding gases. This makes it difficult to analyse. I expect that the Lawrence Livermore lab people can help you do that.
AM
Thanks Andrew, you have been a great help for me in understanding how it all works. I have been working with them over the past few months but I just want to double and triple check my work and numbers before I put them in this report. Thanks again!
  • · Replies 16 ·
  • · Replies 39 ·
17K
9K
