| Thread Closed |
An Unknown Compound |
Share Thread | Thread Tools |
| Oct29-09, 11:14 AM | #1 |
An Unknown Compound
A compound containing element A and oxygen has a mole ratio of A:O = 2:3. If 8.0 grams of the oxide contains 2.4 grams of oxygen... a) what is the atomic weight of A? b) what is the weight of one mole of the oxide? c) what is the theoretical weight of the oxide formed when 28 g of A is heated in excess oxygen? d) what is the % yield if 38 grams was produced from 28 grams of A? 2. Relevant equations .... 3. The attempt at a solution I didn't have any because I barely understood what to do :( can someone please guide me on how to solve this? It'll be of great help ^^ |
| Oct29-09, 11:22 AM | #2 |
Recognitions:
Start with the oxygen. How many moles of oxygen is equivalent to that 2.4 grams of oxygen from the compound?
| Oct30-09, 10:09 PM | #3 |
so I'll convert the oxygen grams to moles right? :)
| Oct31-09, 04:29 AM | #4 |
Admin
An Unknown Compound
Yes. Then try to find out how many moles of the oxide you have (look at the formula).
-- chemical calculators - buffer calculator, concentration calculator www.titrations.info - all about titration methods |
| Mar13-10, 04:31 AM | #5 |
8.0 - 5.6 = 2.4 gO
2.4 gO x 1 mole O / 16 gO = 0.15 moles O A:O = 2:3 A:0.15 = 2:3 [tex]\frac{A}{0.15}[/tex] x [tex]\frac{2}{3}[/tex] 3A = (0.15)(2) 3A = 0.30 A = 0.1 moles Oxygen a) AW = g/mole AW = 5.6 gO / 0.1 moles O AW = 56 g/mole b) 2:3 A2O3 = (56)(2) + (16)(3) = 160 g |
| Mar13-10, 05:54 AM | #6 |
Admin
[quote]AW = g/mole AW = 5.6 gO / 0.1 moles O AW = 56 g/mole[/quot]e Here it becomes obvious - 56 g/mol is not molar of oxygen. It is molar mass of A. ![]() Answers given for c & d are correct, but this is just a simple stoichiometry. You have a balanced reaction equation 4A + 3O2 -> 2 A2O3 that gives molar ratio, you know molar mass of A... I guess it can be symbolic A instead of some well defined element that throws you off. Would it be easier if I will tell you to solve c & d assuming A is the iron? -- chemical calculators - buffer calculator, concentration calculator www.titrations.info - all about titration methods |
| Mar13-10, 09:46 PM | #7 |
4A + 3O2 -> 2 A2O3 if we take the balancing off.. A + O2 -> A2O3 Where did we get A + O2 ? Is this common knowledge? because all I understood was A2O3 since we had a mole ratio of 2:3 right? :D |
| Mar14-10, 05:02 AM | #8 |
Admin
Not sure what your problem is. There are many ways of producing oxides, but direct reaction between the element and oxygen is the simplest one (even if technically not always possible). Even if it is not possible, you were told in the question that 38 grams of A2O3 were produced from 28 grams of A - no matter what the real reaction was, molar ratio of the A and A2O3 will be always the same.
Then A2O3 was given, O[ub]2[/sub] is a common knowledge, A is just the simplest way of approaching the problem. -- ChemBuddy chemical calculators - buffer calculator, stoichiometry calculator www.ph-meter.info - ph meter, ph electrode |
| Thread Closed |
| Tags |
| atomic, chemistry, element, weight |
| Thread Tools | |
Similar Threads for: An Unknown Compound
| 2 Unknown Currents, 1 Unknown emf, and a little confusion to boot! | Introductory Physics Homework | 1 | ||
| IUPAC name for this compound | Biology, Chemistry & Other Homework | 1 | ||
| Say your given a Compound....... | Biology, Chemistry & Other Homework | 1 | ||
| Compound Microscope | Introductory Physics Homework | 0 | ||
| Iron compound | Chemistry | 9 | ||
