Is it possible to integrate e^-mod(x^n) for n>2?
  • Context: Undergrad
  • Thread starter Thread starter KoopaCooper
    Integral
The discussion revolves around the integration of the function \( e^{-\text{mod}(x^n)} \) for values of \( n > 2 \). Participants explore the validity of integrating this function, particularly through power series, and examine the convergence of the series involved. The scope includes theoretical considerations and mathematical reasoning related to calculus.
  • One participant notes the ease of integrating \( \int^{\infty}_{-\infty} e^{-\text{mod}(x)} dx \) and \( \int^{\infty}_{-\infty} e^{-\text{mod}(x^2)} dx \), and questions the validity of a similar approach for \( n > 2 \).
  • Another participant suggests that while convergence is necessary for interchanging summation and integration, uniform convergence is required, and questions the convergence of the final series.
  • Clarification is sought regarding the meaning of "mod(x^2)" and the value of the integral for \( m=1 \).
  • One participant expresses uncertainty about the convergence of the series when evaluated at infinity and mentions that the integral can be expressed in terms of the Gamma function.
  • There is a discussion about the identity \( \int_0^{\infty} e^{-x^n} dx = \Gamma(1 + \frac{1}{n}) \) and its implications for the integral over the real line.
  • Some participants reflect on their educational experiences, noting that they were taught differently regarding the solvability of the integral for \( n \geq 3 \).
  • One participant mentions the recursive nature of the general derivative of tetration, indicating the complexity of the topic.
Participants express differing views on the solvability of the integral for \( n \geq 3 \) and the conditions under which integration and summation can be interchanged. There is no consensus on the validity of the proposed methods for integration or the convergence of the series.
Limitations include the need for uniform convergence to interchange integration and summation, and the unresolved nature of the convergence of the series at infinity. The discussion also highlights varying educational backgrounds regarding the integration of the function.
KoopaCooper
OK, this is going back to a problem I studied back in Calculus class; it's been a few years since I graduated, so bear with me please... :)
It's easy to integrate [tex]\int^{\infty}_{-\infty}\\e^{-mod(x)}\\dx[/tex] (giving a value of 2), and with a bit of grunt-work, the same can be done for [tex]\int^{\infty}_{-\infty}\\e^{-mod(x^2)}\\dx[/tex] (giving the value of [tex]\sqrt{\pi}[/tex]). But I was curious about [tex]\int\\e^{-mod(x^n)}[/tex] for values of n>2.
Would it be considered valid to take the power series of the function and integrate it, then evaulate that at the end points?
For example, for the general case of x to an nth power... (oh heck...I tried to used the forum code but it got so tangled up...here's one I MSPainted earlier instead).
My question is, is this integration and evaluation valid? Have I integrated it properly? Does it count? (I never did check if the integrated power series converges). It certainly appears to work when I evaluated the partial sums of the series with x tending towards infinity, for the cases of m=1 and m=2, but is it legal?
It would work for a finite sum, and I think it works for an infinite sum if the series converges (which it does for your conditions on n)... but I cannot give you an absolute answer, only that I think you are safe here.
You've switched m and n around from your introduction in the attachment!
Ah, it's good to know I haven't completely lost my touch at calculus then. :)
I did switch them? *looks* O bother! That's what I get for using a picture that I created quite some time ago...:-p
Convergence is not a sufficient condition to interchange an integral and a summation: You must have uniform convergence.
I don't see how the final series can have a value? It doesn't converge! If the upper limit was some fixed value rather than infinity we could see from the alternating series test that the series converges because the terms decrease monotonically towards zero (after a certain term, at least) .
I don't understand what the "mod(x^2)" means? Could you clarify what it means, and how you got the value of 2 for when m=1 ?
It so happens that [tex]\int_0^{\infty} e^{-x^n} dx = \Gamma \left(1+\frac{1}{n}\right)[/tex].
Huh, that was meant to be [tex]-mod(x)^2[/tex] - I'm not very good at writing neatly in this BulletinBoard maths code.
OK, I'll do this for m=1.
[tex]\int^{\infty}_{-\infty}\\e^{-mod(x)} = 2\int^{\infty}_{0}\\e^{-x}[/tex]
[tex]= 2\int^{\infty}_{0}\sum^{\infty}_{n=0}\\\frac{-x^n}{n!}[/tex]
[tex]= 2[\sum^{\infty}_{n=1}\frac{(-1)^n}{n+1}\frac{x^{n+1}}{n!}]\\\|^{\infty}_{x=0}[/tex]
[tex]= 2[\sum^{\infty}_{n=1}\frac{(-1)^n\;x^{n+1}}{(n+1)!}\\\|^{\infty}_{x=0}[/tex]
[tex]= -2\\e^{-x}\\\|^{\infty}_{x=0}[/tex]
[tex]= -2\\e^{-\infty} - -2\\e^{-0}[/tex]
[tex]= 0 + 2\1 = 2[/tex]
But for m=2, that is, for the integral of [tex]e^{-mod(x)^2}[/tex], you can't convert the integrated power series back into a simple function, but evaluating that sum for any sufficiently large x (as x --> infinity) does apparently produce [tex]\sqrt{\pi}[/tex] (I ran it through on Excel once).
I didn't know that it could be expressed in terms of the Gamma function, that's interesting to know (my professor never mentioned that).
So, mod mean modulus here?
[tex] mod(x)=|x|[/tex]
So that's how to write it! Heh, I just had a brain freeze about how to write the modulus symbol in forum code, I can't believe that.
Yes, that is what I meant, [tex]|x|[/tex].
*Slaps "n00b" sign on forehead* :p
this implies at once
[tex] \int_{\mathbb{R}}{dx\,e^{-|x^n|}}=2\Gamma\left(1+\frac{1}{n}\right).[/tex]
Huh. For some reason, my class was never taught that identity, and our professor said that
[tex] \int_{\mathbb{R}}{e^{-|x^n|}dx}[/tex]
was not solvable at all for [tex]n\geq3[/tex]. Hence my trying to construct another way. O well, waste of my time. :smile:
Probably meant not solvable in terms of elementary constants and the such. For integer and half integer arguments the Gamma function yields a "nice" value but no such expression has been found for other values.
If you want to get ahead or impress your teacher, try proving the relation.
Heh, I couldn't impress him anyway. :smile: I graduated years ago and haven't kept in contact with anyone from uni, faculty or fellow students.
I've also been working on/off on trying to find the general derivative of the function [tex]y = \\^{n}\\x[/tex] (tetration, positive integer n only), and it seems to be defined recursively and not in a nice easy way either (involving more than one summation sign).
Although differentiating [tex]y = \\^{\infty}\\x[/tex] is much easier, as it essentially boils down to differentiating the equation [tex]y=x^y[/tex]. It's a slightly messy answer:
[tex]y' = \frac{y^2}{x-x\ln(y)}[/tex]
if I recall correctly, but by far easier than for finite power towers of x.
  • · Replies 27 ·
  • · Replies 19 ·
