Midpoint in 3 Dimensions Question (EASY)
The discussion focuses on calculating a point that is 3/8 of the way from point P to point Q in three-dimensional space using vector analysis. The user clarifies that using a scalar multiple of the vector PQ alone does not yield the correct point on the line, as demonstrated by the calculation OP + (3/8)PQ = (-1, -1, 3). The midpoint formula is applied three times to derive points M, N, and R, ultimately leading to the correct position of R, which is 3/8 of the distance from P to Q.
  • Understanding of vector notation and operations
  • Familiarity with the midpoint formula in geometry
  • Basic knowledge of three-dimensional coordinate systems
  • Ability to perform scalar multiplication of vectors
  • Study vector addition and scalar multiplication in three dimensions
  • Learn about the geometric interpretation of midpoints and segments
  • Explore advanced applications of vector analysis in physics
  • Investigate the use of parametric equations for lines in 3D space
Students studying geometry, mathematics educators, and anyone interested in vector analysis and three-dimensional coordinate systems.
carlodelmundo
http://carlodm.com/calc/123.png
My question is:
Why can't we use a scalar multiple like (3/8) PQ instead of using the midpoint formula twice (to get 3/8) ?
PQ = (8, -8, -8), so (3/8)PQ = (3, -3, -3), which doesn't get you a point on that line. What you can do, though, is calculate OP + (3/8)PQ = (-4, 2, 6) + (3, -3, -3) = (-1, -1, 3), which is the same as the answer shown in your problem.
What I've done above is to look at things from a vector perspective. OP is a vector from the origin to point P. PQ is a vector from P to Q, but it is equivalent to the vector from the origin to the point (8, -8, -8). To get to a point 3/8 of the way from P to Q, we have go from the origin to point P, and then 3/8 of the distance from P to Q.
Whoever solved the problem used the midpoint formula three times, not twice: the first time to get a point M halfway between P and Q; the second time to get N, a point halfway between P and M (and a quarter of the way from P to Q); and the third time to get a point R halfway between N and M (3/8 of the distance from P to Q).
Maybe this "graphic" will help you understand better.
P----------------------------------------------------Q
P-----------------------M
P---------N------------M
P---------------R
d(P,M) = (1/2)d(P,Q)
d(P,N) = (1/4)d(P,Q) = d(N,M)
d(P,R) = (1/4)d(P,Q) + (1/2)d(N,M) = (1/4)d(P,Q) + (1/8)d(P,Q) = (3/8)d(P,Q)
  • · Replies 18 ·
