Compton Scattering: Simplifying Equations for Energy and Momentum Conservation
The discussion revolves around the conservation of energy and momentum in the context of Compton scattering, specifically focusing on the mathematical manipulation of equations to eliminate variables such as velocity (v) and photon scatter angle (θ).
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore various methods to eliminate variables from the equations, expressing frustration with the complexity of the resulting expressions. Some suggest using trigonometric identities, while others attempt to substitute variables to simplify the equations.
There is an ongoing exploration of different approaches to manipulate the equations. Some participants provide hints and suggestions, while others express uncertainty about the direction of their attempts. No consensus has been reached, but several productive lines of reasoning are being pursued.
Participants note the challenge of interdependence between variables, particularly how eliminating one variable often necessitates introducing another. The complexity of the equations and the imposed constraints of the problem contribute to the difficulty of finding a clear path forward.
tramar
From the equations:
[tex]h\nu - h\nu' = T= m_o c^2 (\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}-1)[/tex]
[tex]\frac{h\nu}{c}=\frac{h\nu'}{c}cos\theta+\frac{m_o v}{\sqrt{1-\frac{v^2}{c^2}}}cos\phi[/tex]
[tex]\frac{h\nu'}{c}sin\theta = \frac{m_o v}{\sqrt{1-\frac{v^2}{c^2}}}sin\phi[/tex]
[tex]\alpha=\frac{h\nu}{m_oc^2}[/tex]
(representing the energy and momentum conservation for Compton scattering, theta = photon scatter angle and phi = electron scatter angle)
Eliminate v and [tex]\theta[/tex] to obtain:
[tex]T=m_oc^2 \frac{2\alpha^2cos^2\phi}{1+2\alpha+\alpha^2sin^2\phi}[/tex]
See above
This problem has been driving me insane. I know the physics of Compton scattering but when I try to eliminate the v and theta from these 3 equations I just get hopelessly lost in the math... I have about 5 pages of scribbles leading to nothing.
Desperate at this point, some math help would be appreciated.
HInt: [itex]\sin^2\theta+\cos^2\theta=1[/itex]:wink:
I know that... the problem is when I try to make theta disappear, I have to bring in a v. If I want to make v disappear, I bring in a theta. The only way that it seems to "work" gives me the following mess:
[tex]\sqrt{1-\frac{v^2}{c^2}}= \left( \frac{T}{mc^2}+1 \right) ^{-1}[/tex]
[tex]v=c\sqrt{\left( 1-\left(\frac{T}{mc^2}+1 \right)^{-2} \right)}[/tex]
[tex]cos\theta = \sqrt{1-\left(\frac{c}{h\nu'} \right)^2 \frac{(mv)^2}{1-\frac{v^2}{c^2}} sin^2\phi}[/tex]
As you can imagine, taking v and substituting it into the cos equation makes for a disgusting mess that doesn't lead to anything very productive.
tramar said:
I know that... the problem is when I try to make theta disappear, I have to bring in a v. .
I don't see why you say this... just solve the equation
for [itex]\frac{h\nu'}{c}\cos\theta[/itex], square both sides, and then square both sides of the equation
and add the two resulting equations together...
Ok so that gives me:
[tex]\left(\frac{h\nu'}{c}\right)^2=p_e^2-2p_ecos\phi\frac{h\nu}{c}+\left(\frac{h\nu}{c}\right)^2[/tex]
where [tex]p_e=\frac{mv}{\sqrt{1-\frac{v^2}{c^2}}}[/tex] (for simplicity)
Not sure how to proceed... if I solve for p I have to use a quadratic eqn giving another big mess?
The next step would be to eliminate [itex]\nu'[/itex] in favor of [itex]T[/itex] by using your first equation...
So:
[tex]\frac{(h\nu)^2-2Th\nu+T^2}{c^2}=p_e^2-2p_ecos\phi\left(\frac{h\nu}{c}\right)+\left(\frac{h\nu}{c}\right)^2[/tex]
My instinct says to solve for [tex](cp_e)^2[/tex] and then substitute that into energy conservation equation...
[tex]h\nu+mc^2=h\nu'+\sqrt{(mc^2)^2+(cp)^2}[/tex]
...but I'll still have a [tex]p_e[/tex] in there. Not sure if that's the right course of action...
Why not solve the energy conservation equation
[tex]T+m_0c^2=\sqrt{(m_0c^2)^2+p_e^2c^2}[/tex]
for [itex]p_e[/itex] and then substitute that into
[tex]\frac{(h\nu)^2-2Th\nu+T^2}{c^2}=p_e^2-2p_ecos\phi\left(\frac{h\nu}{c}\right)+\left(\frac {h\nu}{c}\right)^2[/tex]
so
[tex]c^2p_e^2=T^2+2Tmc^2[/tex]
After substituting...
[tex](h\nu)^2-2Th\nu=2Tmc^2-2h\nu\sqrt{T^2+2Tmc^2}cos\phi+\frac{(h\nu)^2}{c}[/tex]
And getting rid of the root gives me a massive equation with 12 terms on the right :S
Why do you still have a factor of [itex]1/c[/itex] in the last term?
My bad, the last one doesn't have 1/c.
Subbing in I get:
[tex]2h\nu cos\phi \sqrt{T^2+2Tmc^2}=2Tmc^2+2Th\nu[/tex]
I'll try to solve for T...
Awesome! FINALLY got it.
Thanks a million for your help!
  • · Replies 0 ·
  • · Replies 18 ·
  • · Replies 0 ·
