Smooth and L^2 on R^n. Will it be bounded?
  • Context: Graduate
  • Thread starter Thread starter stradlater
    Bounded Smooth
The discussion revolves around the properties of smooth functions that are in L² on Rⁿ, specifically whether such functions can be unbounded. Participants explore this question in the context of different dimensions, particularly focusing on the implications of smoothness and integrability.
  • Some participants argue that in the case of n=1, a smooth function in L² must be bounded, as being unbounded would contradict its L² property.
  • Others suggest that for n=2 or higher, it is conceivable to construct a smooth function that is unbounded yet still belongs to L², citing examples of functions with increasingly thin and tall ridges.
  • A participant points out the necessity of defining "smooth" and questions whether a sequence of bumps could be considered smooth while remaining unbounded.
  • Another participant asserts that any function in L² must have a finite essential supremum, implying that if a function is unbounded, it cannot be in L².
  • One participant proposes that a smooth unbounded function could still have a finite L² norm if the regions where it exceeds certain bounds have measure that diminishes appropriately.
  • A specific example involving a series of functions is presented, where the pointwise limit is a smooth unbounded function, raising questions about its integrability and the validity of term-by-term integration.
Participants express differing views on whether a smooth function in L² can be unbounded, with no consensus reached. Some maintain that it cannot be unbounded, while others provide counterexamples and theoretical constructs suggesting otherwise.
The discussion highlights the complexities surrounding definitions of smoothness and the implications of measure theory, particularly regarding sets of measure zero and their impact on integrability.
stradlater
smooth and L^2 on R^n. Will it be bounded??
Hello,
If a function, say u, is smooth and L^2 on R^n. Will it be bounded??
In the case of n=1 I would say that it obviously is so. Because if it were unbounded then it wouldn't be L^2.
But in the case of n=2 (or higher). I can imagine a function with a kind of ridge that gets thinner and thinner but higher and higher, the further away from the origin we get. So that it would be unbounded but still L^2.
I guess I was just wondering if this line of thinking is correct? Thankful for any feedback.
stradlater said:
Hello,
You have to define "smooth" ... For n=1 do you disallow a sequence of bumps, getting thinner but taller, as you go to infinity. Such a thing could be infinitely differentiable. But the derivative won't be bounded.
As I understand it the question is about one single function, not about a sequence of functions, Any function in L^2, be it smooth or not, needs to be bounded, in the sense that the essential supremum of |f| is finite, for otherwise neither f nor f^2 would be integrable...
Of course you can always change the values of f on set of measure zero so as to make f unbounded and without changing f (as an element of L^2).
Thanks for the quick answers. With smooth I just meant that all the derivatives exist and are continuous. So with smooth I meant to disallow for the above mentioned example regarding sets of measure zero.
And yes, the question was about one single function, but I think the sequence of bumps were meant as a series of bumps along the x-axis (n=1), i.e. one single function.
So, this bump-function, let's call it f, is unbounded and smooth. Meaning that for every M>0 there is an x and and an epsilon such that f>M on the ball around x of radius epsilon. Couldn't this function still be L^2 if the epsilon went to zero sufficiently fast as M got larger?
The problem for me, I think, is that I haven't studied measure theory. But am I correct if I say that smooth and unbounded implies that for every M>0 there exists a set A, where f>M on A,such that [tex]\int_A dS >0[/tex] . In the same way as above couldn't the L^2 norm of f be finite even if ess sup f isn't? Providing that the measure of A goes to zero as M gets larger??
To make things clearer, consider this example(I think this is the function g_edgar mentioned).
Let [tex]\psi(x)[/tex] be a smooth non-negative function such that its support is contained in the interval (-1,1) and such that [tex]\int_R\psi(x)dx=1[/tex].
Now consider the series [tex]\sum_{k=1}^\infty k\psi ((x -2k)k^3 )[/tex]
I believe this series converges pointwise to a smooth unbounded function f(x). But is [tex]f\in L^1 (R)[/tex]? If we were allowed to integrate the series term by term we would get
[tex]\int_R\sum_{k=1}^\infty k\psi ((x -2k)k^3)dx = \sum_{k=1}^\infty 1/k^2dx[/tex]
But the series doesn't converge uniformly so I guess we aren't allowed to do this??
