How does the mass of Z compared to mass of Y affect the recoil kinetic energy?
  • Thread starter Thread starter Kaxa2000
    Elastic Space
In an elastic collision between two balls, Y and Z, the mass of Z significantly influences its recoil kinetic energy (KE) and momentum. To achieve maximum kinetic energy for ball Z, its mass must be smaller than that of ball Y, as KE is proportional to the square of the velocity. Conversely, for momentum, a larger mass for Z results in greater momentum, as momentum is directly proportional to mass. The conservation of momentum dictates that the initial momentum of ball Y must equal the combined momentum of both balls post-collision.
  • Understanding of elastic collisions
  • Familiarity with the equations for kinetic energy (KE = (1/2)mv²) and momentum (P = mv)
  • Basic knowledge of conservation laws in physics
  • Concept of mass-velocity relationships in motion
  • Study the principles of elastic and inelastic collisions
  • Learn about the conservation of momentum in multi-body systems
  • Explore the relationship between mass, velocity, and kinetic energy in detail
  • Investigate real-world applications of collision physics in sports and automotive safety
Physics students, educators, and anyone interested in understanding the dynamics of collisions and energy transfer in physical systems.
Kaxa2000
Two balls Y and Z collide elastically in space. If Z is initially at rest how would you choose it's mass in relation to Y so that it would recoil with the greatest (1) KE (2) Momentum
Kinetic Energy: KE = (1/2)mv^2
Momentum: P = mv
Would you have to have a smaller mass for Z so that it would recoil with greater KE than Y?
And for momentum would you have to have a larger mass for Z so it would recoil with greatre momentum?
How do you explain them in terms of the equations? I think I understand the momentum...if you plug in larger mass than you have a larger P...but KE I'm not sure? Wouldn't you also have a larger KE if you plugged in larger mass? If Z was really large it wouldn't move it all so I would think it would have to be small would it not?
Anyone have input for this?
Momentum is always conserved for all cases so the ball or block that is going to hit the one that is resting has a constant value of momentum;
as you can see from the equaiton p=m.v the value of the momentum is about the values of the blocks or balls mass and velocity.
So to get the max value of kinetic energy i would take m as a small value because the degree of it is 1, if you double your velocity your kinetic energy would increase as a factor of 4.
(Kinetic energy of a block is 1/2mv2 as you mentioned )
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 25 ·
